LED Circuit Aluminum Base
  • davg
    • Sep 2008
    • 536
    Re: LED Circuit Aluminum Base
    Originally posted by Retro-Hipster
    Ah, nice! As for the brightness issue there, that is likely to happen if you don't have any current limiting in series with your power supply. LED's will essentially grab all the current they can once they start conducting.
    If you have a 100ohm resistor, try sticking that in circuit with that 6v power supply and that should make it much less bright.
    Tks Retro success!! I removed all the LED of one board and replaced the damaged one on each of the other boards with a good one These two boards now light up. Now I have to find some replacements?? I would really like to buy 3 quality modules??
      Cree J series 6V 200mA 3030 should work, Cathode is big pad.
      https://cdn.badcaps-static.com/pdfs/...4ff3bb7beb.pdf
      Or find something similar with 200mA rating or more.
      • Retro-Hipster
        Tinkerer
        • Apr 2019
        • 125
        Nice! I love it when stuff get's fixed. Oh, and, I'd advise against running those panels for any length of time with the one panel out.. I'm sure that is why they died in the first place. lol
        But yes, Cree = quality for sure.
        “Men always seem to think about their
        past before they die, as though they were
        frantically searching for proof that they
        truly lived.”
        – Jet (Cowboy Bebop) -
        • davg
          • Sep 2008
          • 536
          Tks Bud
          • davg
            • Sep 2008
            • 536
            I hear you Tks Retro
            • davg
              • Sep 2008
              • 536
              I have these SM LED's on order off eBay (may be a long wait out of China) They are available from DigiKey and Mouser but the cost is much higher. Mouser is .104 each but their shipping is a min 20.00 unless you spend over 100.00 and DigiKey is .78 each for the low quantities. I can get then off eBay ($17.00 C for 100) (not Cree) I think that will be fine for this project my challenge here was to gain knowledge and thanks to all who responded that was accomplished. First time ever removing and re-soldering surface mount LED components. I wouldn't even pretend to know how that circuit works?? but that's OK thanks to the great help on here.
                • Jul 2011
                • 6070
                The important part of all of this is you gain some information on how to troubleshoot your problem with your LED yard light knowledge is powerful
                When I troubleshoot something that I have not worked on before I google the part numbers and try to understand how this circuit is suppose to work and then I have a game plan on how to fix it
                Just be careful when you buy LED modules from China there quality is not always good do a burn in test on a LED module over night with the voltage and current that the LED module will see what you are going to interest with is two things one how warm does this module get and if the color change when it becomes warm and if your current goes up
                • Retro-Hipster
                  Tinkerer
                  • Apr 2019
                  • 125
                  Ah, something else that I would recommend davg sir, would be to look at getting some buck/boost modules. It's not a true replacement for a bench power supply, but having some means of taking some wall plug power supply (like your 6v one) and slowly ramp up the voltage until it connects can be really powerful. For instance, in this situation, if you had an ok boost converter you could test 2 or 3 leds at a time and slowly ramp up the voltage until they started to light. By doing that, you could see how well matched the new LED's are with the old ones. The reason for finding out if they are well matched is really well explained by Mr Big Clive in this video if I'm not mistaken, but I haven't watched it in quite a while. ^^;; (I'm at work, so watching youtube isn't so good. lol) In reality, the LED's simply won't be matched because they are going to be from a separate batch/manefacturer and that can't be helped, but still might be interesting information to you.
                  But yes, something like this could really help you out! It is a buck boost converter and would let you use your 6v wall adapter (something like a 12v 2a adapter is more preferable) as both a current limited and voltage limited supply from 0.5v-30v.
                  https://www.amazon.com/Converter-DRO...gateway&sr=8-5
                  I think they also sell this with an acrylic case, but just beware of the difference between a buck, a boost, and a buck/boost converter if you buy one. (Buck steps voltage down, Boost steps voltage up, and buck boost does both.)
                  truly lived.”
                    • Jul 2011
                    • 6070
                    I second this
                    • davg
                      • Sep 2008
                      • 536
                      Thanks guys appreciate your input will have a look at that buck/boost converter
                      • astroboypaul
                        Surface Book 2 Performance Base dead
                        by astroboypaul
                        I'm working on a Surface Book 2 performance base (M1032224-004 on white sticker) and would love for some help troubleshooting or where to look next.
                        The tablet when not connected to the base seems to work fine, but:
                        • When tablet is off and connected to the base, it won't turn on.
                        • Connecting tablet that is already on to base there is a windows device detected tone (not sure what device), but tablet remains in tablet mode, keyboard/trackpad don't work, and windows continues to report only 1 battery.
                        • Charger white light turns on when connected to the base, but base battery and tablet
                        04-25-2025, 12:40 AM
                      • u666sa
                        HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                        by u666sa
                        Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                        Platform: ipa32 la-m024p rev 1b
                        Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                        I found a short on the other side:
                        10-04-2025, 05:03 PM
                      • ahmedtou
                        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                        by ahmedtou
                        help me please
                        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                        I will share all the details with you, including the disc information.
                        Code:
                        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                        Current Profile: BD-R
                        Disc Information:
                        Status: Empty
                        State of Last Session: Empty
                        Erasable: No
                        Free Sectors: 12,219,392
                        Free Space: 25,025,314,816 bytes
                        Free Time: 2715:27:17 (MM:SS:FF)
                        Next
                        08-27-2025, 08:49 AM
                        HP EliteBook 850 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                        This specification for the HP EliteBook 850 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Samsonite Base Boost boardview and 850 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-06-2024, 09:00 AM
                        HP EliteBook x360 1040 G5 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the HP EliteBook x360 1040 G5 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G5 + Samsonite Base Boost boardview and 1040 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
