Replace hoverboard MOSFET. Any?
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi There.,
    I have a hoverboard with a fried RU6888R mosfet
    According to PDF, it is a N channel 68volt 88 Amp MOSFET, TO-220
    Can I just use ANY MOSFET which is N channel, >=68volt, >88Amps, in TO220 format? Also same pin order "GDS"
    I can't find any "official" replacement for this one I'm looking for
    Thanks!
    • 31139
    Re: Replace hoverboard MOSFET. Any?
    if you also watch the gate capacitance < relates to switching speed
    and the Rds-ON / on resistance < must be equal or lower or it will generate more heat.
    • edugimeno
      • May 2017
      • 581
      • Spain
      Thanks STJ, will 6mOhm to 8mOhm be noticeable?
      I found IRFB4410 to be a candidate but has these 2 extra mOhms...
        • 31139
        that should be fine.
          RU6888R has input capacitance of 2900pF.
          IRFB4410 is 5150pF.
          It may not be turned ON/OFF fast enough, may be the circuit has dead time adjustment.
          https://cdn.badcaps-static.com/pdfs/...19d1be1cc7.pdf
          " Typical values of input (Ciss), output (Coss) and reverse transfer (Crss) capacitances given in the data
          sheets are used by circuit designers as a starting point in determining circuit component values. The data
          sheet capacitances are defined in terms of the equivalent circuit capacitances" Also read about Gate Charge.
          • edugimeno
            • May 2017
            • 581
            • Spain
            Ok, but in this case this is for a hoverboard controller board. This mosfet drives one of the 3 coils in a wheel. It will have a switching frequency of 3x Rev Per Second, so basically if the wheel is 5.5" diameter and the max speed is 15kph, max speed will be 10 rps at full speed, so it will probably switch (only af full speed) af 30 Hz. Maybe my maths are a little wrong and it has to switch 2 times for each turn which will give 60 Hz or maybe even double, but we're moving in this range.
            Will this capacitance still be critical in this particular use?
            Thanks!
            IRFB4410 is 5150pF.
              • 31139
              no, the motor is not driven by one pulse per field for each revolution.
                You need to trace the cicut from the Gate of the MOSFET's to the IC that drives those MOSFET' s, once you find the IC then look up the spec sheet and application notes/circuit then you can see how the Motor is driven.
                • edugimeno
                  • May 2017
                  • 581
                  • Spain
                  Someone reverse-engineered an schematic, link here
                  The oulse comes from a microcontroller, 3 transistors are in between the micro and the mosfet
                  • edugimeno
                    • May 2017
                    • 581
                    • Spain
                    Actually the mosfet in this schematic I linked above, from another hoverboard (but they are all the same), uses an 110n8f6 mosfet with an input capacitance of 9000pF, so this leads me to think that 5000pF may still be good, am I right?
                      As you can see, it is 3-phase drive topology. You see how the MOSFET's are connected, if one is not completed OFF while another is on then you will have disaster, since it is MCU based, they can adjust dead times.
                      https://hackaday.io/project/3176-gat...time-insertion
                      http://www.modularcircuits.com/blog/...ridge-control/
                      http://www.ti.com/product/LM5106
                      You can try the substitute and find out.
