PIC16F676 Program, remote control switch for 2Light & 1Fan.
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    • smd electronics
    Hello Dear Friends,
    I have a device used in my room to control 2 light (On/Off) and 1 fan (On/Off+Fan Speed Control).
    I have made the circuit same to same. There is an IC : PIC16F676. I copied the IC to a new IC and installed in my new circuit board. But it does not work. But if i put the original/Old ic with the new board it works well.
    What i think the ic is programmed and locked anyway. I am attaching the original program. Please help me if anybody can help to make this file workable.
    Thanks.
    • 31607
    Re: PIC16F676 Program, remote control switch for 2Light & 1Fan.
    the protect bit has been set.
    also, that is not a hex file - it's a bin file.
    changing the filename does not change what it is.
    • mariushm
      • May 2011
      • 3799
      Re: IC PIC16F676 Program, remote control switch for 2Light & 1Fan.
      The fact that the HEX file compresses to 84 bytes should tell you that you didn't actually copy the program from the PIC chip.
      The copy protections probably make the reader return null bytes or 0xFF bytes instead of actual contents.
      Open the hex file with a text viewer or hex viewer and you'll see what I mean.
        • 31607
        you cant, it's not a hex file - it's a bin file that is miss-named.
        • masud
          • Jul 2011
          • 317
          • Bangladesh
          • smd electronics
          Whatever the file is, can anyone give me idea to make this file workable?
          Please advice. Thanks.
          • mariushm
            • May 2011
            • 3799
            You can't make the file workable, because you didn't actually copy the code from the microcontroller into the file. The file doesn't actually contain the code in the microcontroller.
            The software you used simply wrote the bytes the microcontroller gave it into the file
            Because the protection bits were set during the last programming, the microcontroller simply sent empty bytes (0xFF or 0x00) instead of the actual code, when the software asked for those bytes.
            So your only option is probably to write the program yourself, from scratch.
            Well, that is your only option unless you have expensive microscopes or x-ray machines and the knowledge to figure out if a bit is 1 or 0 based on how chip looks physically
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Really? Knox'ed out as if it's a DVD player, FFS! :eek:
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • masud
                • Jul 2011
                • 317
                • Bangladesh
                • smd electronics
                Dear friend,
                i can't write/understand this program.
                what i can do only read/write with a programmer. I have the old/original pic16F676. Now, can anybody tell me how i can make a clone of the pic16F676?
                Thanks.
                  • 31607
                  if "protect bit" has been set then you cant read the chip.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    That sounds like some "big music"-like anti-copy stuff! It's the same kind of stuff that makes the RIAA and MPAA execs elated. And of course, the same kind of stuff that makes the big-3 record companies elated...
                    Arc A770 16 GB
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      I fear that one day, we'll have the same kind of thing on motherboard BIOSes!
                      Then, what would be next? The people that were complaining of "TCPA" back in 2005 and 2006 saying that they were right, and thus we're doomed!
                      Arc A770 16 GB
                        • 31607
                        there are already eeproms that need a password to "unlock" them.
                        they show up here & there - in MEGATOUCH quize maschines for example.
                        • kc8adu
                          • Nov 2003
                          • 8835
                          • U.S.A!
                          this is to prevent corruption during a glitch.
                          key has to be sent to enable the chip to accept a write.
                          the protect fuse on the pic is to prevent copying.
                          but there are ways of circumventing this too.
                            • 31607
                            no, the eeprom password is to block copying.
                            • Nilag
                              • Dec 2022
                              • India
                              Originally posted by masud
                              Hello Dear Friends,
                              Thanks.
                              Dear I have completed full tested code. Pl email me: vu3naa@gmail.com
                              • istvanszasz99
                                Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                by istvanszasz99
                                Product ID: RZ09-0421
                                Motherboard: CH580
                                Bios File Size: 32,768 KB
                                Dear Forum Readers!
                                !!! MY RAZER BLADE...
                                11-24-2025, 05:52 PM
                              • tmhobadcap
                                Pioneer VSX-522-K remote control not working???
                                by tmhobadcap
                                I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                12-24-2020, 01:44 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                Hi everyone
                                09-06-2025, 05:47 PM
                              • piipo
                                Old Privileg 5.1 speakers remote control question
                                by piipo
                                Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                                09-18-2024, 01:55 AM
                              • Boardview and Schematic Bot
                                Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-06-2024, 05:30 AM
