Thermal Circuit Breaker Problem - can we fix it?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have this ETA 3120-F321-P7T1-R14XB3 Circuit breaker from a Hill DX3000 Power Amplifier.
    The first problem I found with the amp was a faulty 25A Bridge rectifier FB2506 that was short circuit on one leg AC to negative
    I've replaced that but the amp has no power. That is because the ETA circuit breaker is open circuit on one pole. The other pole switches OK. The primary of the transformer seems OK (not short or open and doesn't look distressed) so I think that ETA circuit breaker is the only other problem I need to fix.
    Problem is finding a replacement. I can find some similar that have 3120-F321-P7T1-xxxxxx but the last digits are different.
    The similar ones I can find are silly expensive like 40 quid or more and mostly in the USA.
    What is inside these circuit breakers? I have had success in the past dismantling multipole switches and fixing them (usually heavily coroded contacts)
    If the circuit breaker is actually a double pole breaker and one pole is working, could i just short out the o/c side?
    Add an inline fuse for safety instead?
    Looking for a replacement, an equivalent part that isnt silly money, or how to dismantle and fix this one
    best regards
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • R_J
    • 9557
    Re: Thermal Circuit Breaker Problem - can we fix it?
    Here is the pdf for the E-T-A 3120 series
    They do have a "switch only" without the breaker that would fit, and you could add a seperate circuit breaker in ine
      • Jul 2011
      • 6045
      That part number might made for just that company that made that amp
      So you might not be able to get the exact part
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Thanks for the advice
        One pole of the circuit breaker switches fine, so I think i will refit it and just another circuit breaker where the leads go to the faulty (open circuit) pole and it should work fine
        Something like this one https://www.ebay.co.uk/itm/Techna-T1...EAAOSwszZa5-hL I can get for less than £5
        Rich
          • Jul 2011
          • 6045
          Rich
          I would recommend replacing it with two separate breaker because I would not be surprised if the other half might be damaged in some way
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • beetle1303
            Electric oven tripping circuit breaker after turned on for 3-5 minutes
            by beetle1303
            My electric oven was working fine all the while from purchased 2 years ago. I have been using it weekly for about a year, but stopped using for a year now since then.
            When I turn it on again yesterday, the tripped the circuit breaker and whole house no power supply. I reset the circuit breaker, and retried. Same thing happened.
            This is what happened:
            - Turned on the oven power supply, set temperature to 200c, everything worked for a few minutes, then the power tripped. Oven was warmed/hot.
            - Reset circuit breaker, retried, same thing happened.
            05-03-2020, 09:18 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
