BGA reballing without balls?
  • capwizard
    • Jun 2016
    • 1991
    I try to do BGA reballing without the balls?
    I was inspired by the fact that I saw some people didn't use balls (use solder paste)when they were repairing the cell phone.
    Is it possible? We don't even use stencil and solding paste? Solder the bag righr to PCB?
    Because I hate to do this....at picture 4
    Pictures 3 is A homemade COMPAQ BGA reballing machine.
  • capwizard
    • Jun 2016
    • 1991
    Re: BGA reballing without balls?
    My idea is if we can have both PC Board and BGA chip Implanted nipple (Breast augmentation) like pic1
    but... how can i do it?
    put BGA chip under silicone oil then work hot solder iron with solder on it. Using surface tension to form a semi-spherical ball. i called....BGA Breast Implant.
    but.... how about PCB? We need to built a dam or levee on it with plumper's putty then work hot solder iron with solder on it to form a semi-spherical ball. i called ....PCB Breast Implant.
      • 31066
      your idea has a flaw, you wont keep the chip lined up while you try to reflow it, it will slide between the balls on the pcb and make a mess.
      • capwizard
        • Jun 2016
        • 1991
        Believe it or not, they (BGA and PCB) will automatically correct the position because of the melted solder surface tension.
        There is another way to solve the problem as you mentioned, is to use the computer aid position, hot air lets both BGA chip breasts and PCB breasts are melted then computer arm slowly put down BGA chip and welded both of them together.
        And manufacturers don't want to use such cumbersome steps then cause many of these BGA cold solder joint problems.
        BGA reballing - watch spheres align during reflow
        https://www.youtube.com/watch?v=KjMle1uYf6Q
        Samtec ZRAY Self Aligning HD
        https://www.youtube.com/watch?v=DRR25udlB2s
        Reballing
        https://www.youtube.com/watch?time_c...&v=0qacORJQjyY
        How to reflow solder electrical components without stencils
        https://www.youtube.com/watch?v=AXBflP_4fdQ
        Solder Surface Tension and Why You Should Care
        https://www.youtube.com/watch?v=opPDZnmrPPE
        • Sparkey55
          • Jan 2010
          • 1523
          Without the balls the pressure from the heatsink will squeeze the solder flat resulting in possible shorts.
          • capwizard
            • Jun 2016
            • 1991
            We have half the ball on BGA chip and the other half ball on PCB. Should not be short-circuited and the hotter the PC-Board the better contacts.
            • Sparkey55
              • Jan 2010
              • 1523
              What you are trying to do will not be stable enough to work longterm. Balls on balls will teeter under the slightest vertical pressure causing stress to make them want to slide sideways. You should rethink this idea.
              • capwizard
                • Jun 2016
                • 1991
                Thanks for your suggestions
                Then we can improve to flatten quilt a Semi-Spherical Surface by heat treatment or grinding to flattening spherical top surface. pic1
                But I have a question, what is this shape? i mean name of this flattening spherical ball? bowl shape ....Super Bowl shape..!
                • arisravi
                  • 20
                  • india
                  there is a video in ifixifix (ifix.net.cn)youtube channel reballing tv bga chip with solder paste and stencil.they say to reball with existing solder
                  • capwizard
                    • Jun 2016
                    • 1991
                    thank you my friend.
                    Would you please upload the videos?
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      The shape of DISASTER TO COME.
                        • 31066
                        you can buy the balls, and the frame - so i dont even see the point.
                        • CapLeaker
                          Leaking Member
                          • 8195
                          something like this? https://www.youtube.com/watch?v=DLIlL8Eb1o0
                          • capwizard
                            • Jun 2016
                            • 1991
                            I must admit that I was told by Sparkey55. Breast transplant is a big failure.
                            I used vegetable oil instead of silicone oil but breasts does not growing up even under the oil. so this is a failure. But I will improve it. while heating up BGA chip to 230F and adding ordinary solder to form breasts.
                            I brushed some solder paste on it and started BGA soldering. IC chip and PCB did Soldered together. This time I used this board is a junk tcon. Next time I will move PCB from working TV set to do the experiment.
                            pic 2 has vegetable oil inside the levee.
                            pic 8 IC chip and PCB did Soldered together with no gap.
                            • capwizard
                              • Jun 2016
                              • 1991
                              I have those things. I just want to try a faster and cheaper, anti-traditional, way to do BGA rework helping people in Africa to repair TV with hair dryer and hair straightener.
                              Solder ball placement for BGA reballing
                              https://www.youtube.com/watch?v=cCFgySeN8Ns
                              BGA Single ball rework - Finetech rework station
                              https://www.youtube.com/watch?v=xmJYU_7P1C8
                              Ball Grid Array Rework: Package-on-Package Devices - Intel
                              https://www.intel.com/content/www/us...ork-video.html
                              Motherboard Repair: Ball Grid Array Socket Rework
                              • capwizard
                                • Jun 2016
                                • 1991
                                This person is so powerful that he directly performs breast transplant surgery by hand.
                                IC Reballing Without Solder Paste/Balls | Perfect Hand Reballing Forever
                                https://www.youtube.com/watch?v=QAv1UKDi_eg
                                I love this person very much, he directly uses my theory. But I won’t do it one by one. I have to do it all at once.
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  • United Kingdom
                                  you need balls to do it properly .
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    CONS:
                                    1. BGA solder ball has shelf life.
                                    The solder alloy itself should not change composition significantly over a period of several years. The main potential issue is oxidation of the surface of the BGA solder ball. Even when stored properly air will eventually make it's way to the solder surface and oxidation will occur.
                                    As the oxide layer grows the balls will become more difficult to solder. The rate of oxidation is slow enough that the balls will be usable for at least two years, but may be difficult to use after that time.
                                    2. BGA solder balls have different sizes. pic 1
                                    PCB Feature Sizes For Standard BGAs
                                    Ball Pitch Via Diameter Trace Size
                                    0.8mm pitch 18 mil 4-5 mil
                                    0.65mm pitch 16 mil* 12 mil 4 mil* 4 mil
                                    0.5mm pitch 10 mil 3 mil
                                    0.4mm pitch 10-8 mil 3 mil
                                    3. BGA solder balls are high price. 1kg = $300
                                    4. BGA solder balls must be used with BGA stencils and holders.
                                    5. BGA solder balls are not easy to manage, run all over the place.
                                    6. The BGA chip center part is not easy to solder with appropriate temperature.
                                    i hate BGA solder balls!
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      I saw sandwich cheese slices when I had breakfast. I suddenly had an idea why can't we make BGA solder paste slices that looks like this. pic 1
                                      solder flux is made of rosin, We can mix solder powder with rosin into thin slices like sandwich cheese slices and very convenient to use.
                                      Cut it into the size you need and then sandwich it with BGA chip and PCB.
                                      BGA reballing rework just as easy as eating your breakfast. Do you think this will succeed?
                                      • Sparkey55
                                        • Jan 2010
                                        • 1523
                                        Gee Wiz ( or is that Cheez Wiz ) guy. You need to enroll into the Think Tank at MIT.
                                        • petemanuk
                                          BGA solder balls not connecting - help pls
                                          by petemanuk
                                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                          11-16-2022, 05:21 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • Stanley1843
                                          BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                                          by Stanley1843
                                          has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                                          06-22-2024, 11:06 AM
                                        • menshawy
                                          Question about solder paste vs solder balls
                                          by menshawy
                                          hi friends
                                          what about using solder paste to reflow vram because it is easier than solder balls
                                          but it will working perfectly or it will die after short time ?
                                          I need your experience
                                          thanks
                                          12-04-2021, 07:49 AM
                                        • DynaxSC
                                          Each GPU reballing produces different MATS results, looking for root cause ?
                                          by DynaxSC
                                          I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
                                          1. When I received the card Mats showed one memory with errors.
                                          2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
                                          3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
                                          4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
                                          5. Made...
                                          12-11-2024, 07:44 PM
