BGA reballing without balls?
    • 30983
    Re: BGA reballing without balls?
    put carbon dioxide into your solder-ball pot to remove the air.
    • capwizard
      • Jun 2016
      • 1991
      lol .................. You are smarter than MIT students.
      It will be better to use Cheez Wiz squeeze bottles. pic1
      BGA solder paste squeeze bottles.
      I have a question? can we do it on Pam Organic Olive Oil Cooking Spray.....i mean BGA solder paste rework spray. Special formula can spray out solder powders and fluxes.
      lol ...than we can make Soda drinks....Coca Cola
      • Sparkey55
        • Jan 2010
        • 1523
        I have a question? can we do it on Pam Organic Olive Oil Cooking Spray.....i mean BGA solder paste rework spray. Special formula can spray solder powders and fluxes.
        Capwizard Cola and BallBurgers?
        • capwizard
          • Jun 2016
          • 1991
          Finally, my dreams come true.
          first.....I want to thank all the people involved here and I wanna thank my teachers and my wises and my children and I want to thank Badcaps let us have a place to show our talents.....and i wanna thank.....I am watching the Grammy Awards.
          first mix solder powders and lard (or candle wax) together in the heat then let it freeze for 50 minutes to from a layer, cut into thin slices and use with BGA reballing work station. pic1
          I have a question: Because of the difference in the proportion, how can solder powders and wax be evenly distributed?
          Tallow can also be used as flux for soldering.... Wikipedia
          • petemanuk
            BGA solder balls not connecting - help pls
            by petemanuk
            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
            11-16-2022, 05:21 AM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • Stanley1843
            BEST 505 Vs Mechanic Brand Reballing Balls with Lead
            by Stanley1843
            has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
            06-22-2024, 11:06 AM
          • menshawy
            Question about solder paste vs solder balls
            by menshawy
            hi friends
            what about using solder paste to reflow vram because it is easier than solder balls
            but it will working perfectly or it will die after short time ?
            I need your experience
            thanks
            12-04-2021, 07:49 AM
          • DynaxSC
            Each GPU reballing produces different MATS results, looking for root cause ?
            by DynaxSC
            I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
            1. When I received the card Mats showed one memory with errors.
            2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
            3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
            4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
            5. Made...
            12-11-2024, 07:44 PM
