Need help to "convert" a washing machine
  • PinGuy
    • Oct 2016
    • 74
    • Argentina
    Hi guys, I need a bit of help to resolve an issue with a washer.
    A friend likes bringing all his equipment from the US (Argentina based). He has a Whirlpool washer (model WFW97HEXL0) that has about 7-8 years of daily use so it is about to die in the near future.
    So he brought a new one (model WFW92HEFU0). He plugged it in to his big 220-110V transformer (same used for the other washer), and it was dead. No buttons on the from panel responded at all.
    He reported it DOA, then arranged to have a new one shipped out, this time he received model WFW92HEFC0, to find out it was also dead!!
    All it does is turn the drum lights on when opening the door. But the buttons do not respond at all, just like the other washer. Nothing lights on the control panel. We double checked that there are no loose connections to the front panel or anywhere, so this must be something else...
    Washer's label states 12A, 120V, 60Hz.
    We have 50Hz here, could it be some sort of protection on the new models that prevent them to turn on when on 50Hz? The old model always worked on 50Hz... and still does, but it makes a lot of noise...
    Any help will be more than appreciated!!
    Attached pictures of the mainboard.
  • R_J
    • 9553
    Re: Need help to "convert" a washing machine
    That could be the problem, It could be that the board looks at the a/c line frequency to calculate wash times etc.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      50 hz can be a problem, mostly with CRTs. Argentina, unlike Mexico and Colombia, is 50 hz, I heard.
      And I heard that even Brasil is 60 hz, but a franken-mix, reportedly some spots at 50 hz spec and others at 60 hz spec! (much like Japan, I heard! Where western Japan is 60 hz spec and eastern Japan is 50 hz spec!)
      I heard that ROC and ROK are 60 hz spec as well.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • PinGuy
        • Oct 2016
        • 74
        • Argentina
        So is it right to guess that one of the inputs in the µC will show a 50Hz signal? And if I lift the pin and inject 60Hz pulses with an arduino it would power up? Or this is just a hopeful fantasy of mine?
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Does it throw any error codes?
          Awful big heatsink for a "conventional" washer! Wanna bet it's got a VFD?
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            you could test it with a generator if you have one . 3kva should just about run a washing machine . 5kva would be better though .
              • 31084
              a 20% difference in frequency may mess timing up - but unlikely as they usually use a switching psu running an atmel microcontroller with internal rtc,
              but it shouldnt stop the machine starting up!
              • RJARRRPCGP
                • Jul 2004
                • 6304
                I was thinking the same thing, unlike a CRT of course! With a CRT, I would expect the timing to get messed up!
                Unless it's a "anti regional feature" designed to intentionally lock out people in 50 hz regions, such as Europe, central Asia and PRC, of course.
                Smells like a firmware lockout.
                Most likely when it gets below 55 hz or the like...
                Arc A770 16 GB
                • PinGuy
                  • Oct 2016
                  • 74
                  • Argentina
                  Nothing, it is totally dead except for the drum LED turning on when opening the door.
                  That would be great, but unfortunately I don't have access to a 110V 5KVA generator here.
                  a 20% difference in frequency may mess timing up - but unlikely as they usually use a switching psu running an atmel microcontroller with internal rtc, but it shouldnt stop the machine starting up!
                  That's what I thought as well, and that's why I believe they added a check. The previous washer worked perfectly with 50Hz during its lifetime. I find it too drastic to show as dead due to a change in frequency. But unpacking two new washers from the box to find them DOA is very strange as well.
                  • PinGuy
                    • Oct 2016
                    • 74
                    • Argentina
                    EXACTLY!!!! Looks like a firmware lockout. The thing is how to circumvent that. I will try and check with the scope if I find 50Hz arriving at the µC...
                      • 31084
                      what's the crystal frequency on the microcontroller??
                      if they are fucking around, it may be configured by a jumper - but your pics are too low-res to zoom into.
                      • PinGuy
                        • Oct 2016
                        • 74
                        • Argentina
                        ...I don't even know which µC is, the whole board seems to have been bathed in epoxy, and the component codes can not be read
                        I also wonder if Whirlpool enables code protection or not on their micros...
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          You don't need a 5KVA genset -- as long as you don't engage the drum motor/water pump! Instead, you need just enough power to convince the electronic that it is attached to 60Hz mains; THEN see if there are any different reactions from the display/controls.
                          • PinGuy
                            • Oct 2016
                            • 74
                            • Argentina
                            I'm uploading some more pics, all I have for now, sorry for the shitty res, will try to make better.
                            Yes, it's just that 110V generators are not a common thing here, all 220V
                            • R_J
                              • 9553
                              Why don't you contact whirlpool and ask them? It never hurts to send an email and ask. Maybe they would be willing to exchange the board
                              If you have a generator that you can change the frequency, connect it to the transformer, then to the washer, Then see if it will at least give a display
                              • petehall347
                                • Jan 2015
                                • 4427
                                • United Kingdom
                                use 220v generator with transformer .
                                • PinGuy
                                  • Oct 2016
                                  • 74
                                  • Argentina
                                  Thanks guys, will check in the coming days and report back
                                    • 31084
                                    pictures are terrible - what the hell did you use??
                                    • Curious.George
                                      • Nov 2011
                                      • 2305
                                      • Unknown
                                      Use "his big 220-110V transformer". With no motor load, there's no practical difference between running 50Hz through that vs. 60Hz.
                                      I suspect there's a VFD in there and they exploited knowledge of the line frequency in its design to cut down on filter caps. The software that does the riming (of the VFD switches) might not know how to handle a shorter mains "period".
                                      [You don't know what assumptions were made in the design so you can only start by trying to mimic the INTENDED application environment, then incrementally see what works/doesn't work.]
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Is this a direct-drive (DD) washer? If yes, what happens if you turn the drum very quickly by hand? Try it both with the washer plugged into the wall and unplugged. Rotating the drum by hand very fast should/may generate enough back EMF to turn on the control panel electronics - at least this seems to work on our LG washer model WM2050CW (from 2009).
                                        Looks like the most reasonable explanation to me as well.
                                        Noise from when the drum is turning? If so, that's just a ball bearing replacement job, which requires taking apart pretty much the whole washer. Not too hard to do (I did it myself, and I am no mechanic and not very physically strong), but will take an hour or two, at least.
                                        ... And yes, I realize you're asking about the new washer and not about fixing the old one. But just thought I'd mention that anyways. Might be just easier to fix the old one in the end.
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • mojos911
                                          ASko washing machine User interface Display
                                          by mojos911
                                          I got a Asko washing machine that has had the flat ribbin cable sustain damage from some corrosion. I have tried to repair it but the ribbon cant sustain the repair and keep breaking. I was trying to source a new LED display but I cant figure out how to try and source one. the information on the back of the display is 13669-LED-A-A173-161007-RoHs. Its also a negative display witha 17v supply for the LED back light and the connectors are 26 pin x 2. What do i have to provide to try and source one of these?...
                                          02-02-2025, 05:03 AM
                                        • mojos911
                                          Fisher and Paykel 10 kg top-load washing machine LED identification
                                          by mojos911
                                          I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
                                          If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!...
                                          01-17-2025, 06:54 PM
                                        • stomanata
                                          No spin on washing machine AEG L6FBA674
                                          by stomanata
                                          This washing machine has power module emc18aecn1 and programmer ewx14931 914913208.
                                          It stop after electric shock.
                                          When i choose only spin it show 12min remaining. After 1min it start drain pump, after
                                          second it start relay (measured 12v ot relay`s coil) that deliver 230V to power module.
                                          This is also ~1second and then pump and relay stop. After ~2min this repeat - pump,
                                          after it relay and both stop.
                                          There is no error.
                                          Can somebody help me to try to fix it?
                                          08-11-2024, 10:39 AM
