Mosfet goes from reading to OL
  • Icitte
    • Aug 2011
    • 61
    HI guys
    I have a Toshiba Mosfet K3569
    When I test it, the reading between D and S (after turning on) get from a voltage and getting higher until OL in an seconde or so. Is that a normal situation or a bad MOSFET?
    All bad mosfet video I saw on youtube only show shortened reading between D and S .
    And sorry if my english is bad!
  • redwire
    • Dec 2010
    • 3900
    Re: Mosfet goes from reading to OL
    It is normal, testing a mosfet from D-S, the gate is sensitive to static charge.
    If you first "charged" the gate to turn it on, then it will slowly lose charge with the gate not connected.
    You must short G-S to ensure mosfet is off. Then look for a short or leakage across D-S.
    To look for a short or leakage across G-S or G-D, there is nothing to worry about.
    • Brucetafer
      • Jun 2018
      • 133
      I just changed 2 brand new mosfets that tested perfectly fine, but wouldn't close the gate with a load... so just replaced them with budm recommendations..
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • irfan karatela
        MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
        by irfan karatela
        I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
        I havent found any shorts on the board.
        I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
        On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p...
        01-20-2025, 07:15 PM
      • tofik
        MOSFET equivalent K8A60DA
        by tofik
        Hello guys,
        I have a shorted MOSFET K8A60DA with the following characteristics:
        Type Designator: TK8A60DA
        Marking Code: K8A60DA
        Type of Transistor: MOSFET
        Type of Control Channel: N -Channel
        Maximum Power Dissipation (Pd): 45 W
        Maximum Drain-Source Voltage |Vds|: 600 V
        Maximum Gate-Source Voltage |Vgs|: 30 V
        Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
        Maximum Drain Current |Id|: 7.5 A
        Maximum Junction Temperature (Tj): 150 °C
        Total Gate Charge (Qg): 20 nC
        Rise Time (tr): 25 nS
        Drain-Source
        07-19-2023, 05:18 AM
      • alro7779
        MOSFET? Is its voltage reading normal?
        by alro7779
        Hello, guys!
        Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
        Yesterday, 08:19 AM
      • Tarot Superstars
        Reading N-Channel Mosfet Junctions (1N65)
        by Tarot Superstars
        Hi.
        I have a Mosfet in a power adaptor circuit and I want to know what is the Gate, Drain and Source.
        I have a data sheet and it shows which is the gate (#1) and I assume 2 and 3 are Drain and Source.
        But when I read it with a multimeter I read that it's likely not that.
        It seems to show that wire 3 is the gate and the other two are drain and source.
        I want to know because I want to design tests on the mosfet to see if it is broken.
        However, the gate of U1 (the pulse width modulator) is connected to wire 1 indicating it IS the gate...
        09-27-2023, 01:46 PM
