Solder paste - Syrine vs Container?
  • caphair
    • Nov 2011
    • 1249
    Looking to get some solder paste and wondering the difference between the two. Is 10cc equivalent to 42g? What does XG-50 (container) vs XG-40Z (syringe) mean? Does one have a better shelf life due to container etc? Any info would help thanks
    • 31255
    Re: Solder paste - Syrine vs Container?
    the syringe is for a dispenser, the pot will need a stencil & other shit,
    what are your plans?, because you can get in a real mess with that stuff.
    • caphair
      • Nov 2011
      • 1249
      For mobile repair using stencils
      • Brucetafer
        • Jun 2018
        • 133
        thats just their part number, i have the same stuff, not really that good in my opinion, but it works for the price for sure.. my syringe is 1000x easier and cleaner to use and doesn't get contaminated like the jar.. but it all depends on what you are using it with..
        • caphair
          • Nov 2011
          • 1249
          Do they both have the same amount in them?
          • Brucetafer
            • Jun 2018
            • 133
            no, the syringe is maybe 10 grams less of material.. but you get about the same after the waste product of the jar, i.e. left on your stick etc.. i only have the jar for dipping leads into for jumpers and other odds and ends.. both have their place on my bench.
            • dicky96
              Solder paste recommendations please
              by dicky96
              Hi guys. Well I thought solder paste was just solder paste but apparently not
              I watched this short video
              https://www.youtube.com/watch?v=uSb1fgCMUug
              I want to try solder paste for resoldering BGA chips and LGA sockets as I am having no luck at the moment. I have no problem safely removing the old part, it's getting the replacement one to solder which is where I am going wrong. The Type 5 solder paste link he gives in the above video says it is not available.
              I want to use the paste like in the video on this thread
              https://www....
              05-11-2020, 03:31 AM
            • menshawy
              Question about solder paste vs solder balls
              by menshawy
              hi friends
              what about using solder paste to reflow vram because it is easier than solder balls
              but it will working perfectly or it will die after short time ?
              I need your experience
              thanks
              12-04-2021, 07:49 AM
            • Veyron7887
              Laptop overheating after replacement thermal paste
              by Veyron7887
              Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
              11-24-2024, 05:08 AM
            • myth77
              UV solder mask - high temp resistent, recomendation?
              by myth77
              Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
              Is there any solder mask...
              03-28-2022, 04:04 AM
            • caspian
              Can thermal paste cause corrosion?
              by caspian
              Dear members,
              I have got an ordinary gray thermal paste that has no name/model on the box.
              I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
              I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
              Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
              Is it safe to leave the thermal paste on the pins?
              I guess the thermal paste...
              06-19-2020, 10:47 AM
