Fixing a pealing PCB contact
  • evilkitty
    • Nov 2017
    • 299
    I know these happen to be ground pins, so bypassing it would be easy
    buy is the proper way to glue them down, if so what kind of glue, supper glue, hypoxy, etc.?
    • 31277
    Re: Fixing a pealing PCB contact
    with decent epoxy.
    • vinceroger69
      • Mar 2012
      • 6714
      CircuitWorks CW2500 as used in this video looks good stuff
      https://www.youtube.com/watch?v=vx50YtEC2S8
      • diif
        • Feb 2014
        • 6978
        • England
        Yes, it's good stuff, but not cheap.
        • evilkitty
          • Nov 2017
          • 299
          So would JB Weld Kwik or original be ok to use?
          https://www.amazon.com/J-B-Weld-8276.../dp/B0006O1ICY
          https://www.amazon.com/J-B-Weld-8265.../dp/B0006O1ICE
          I have both on hand
          i could use some electrical tape to keep it off the other contacts and then clamp (tape would protect pcb from clamp) it and let it sit a day and use some rubbing alcohol to get any tape glue off
          or would that just be a bad way to do it?
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            being edge connectors i would try superglue . should only need pushing onto socket once. whatever you use it needs to be very runny so it is very thin .
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • mitsu2k
              The Real Dangers of conductive glue.
              by mitsu2k
              I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
              Here is an experience I...
              04-16-2023, 06:29 PM
            • howardc64
              Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
              by howardc64
              Samsung have been using this style LED connector for few years now
              Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
              The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
              10-12-2025, 08:13 PM
            • wolf1976
              remove pcb operation board from fridge candy
              by wolf1976
              hi to all i have the pcb you can see from the fotos
              in the plug included in the red circle I have two pins that are burnt black and connected to the thermostat contact my question is how does this board come out I imagine I have to peel off the mask from the front that includes the malfunction lights etc but I don't know if I have to use heat and also what glue I will use to re-glue it and secondly what could have caused this blackening on the plug pins bad contact of the thermostat that made an arc and passed a lot of current momentarily maybe it needs to be changed...
              04-28-2025, 04:24 PM
            • digtalhd
              Remove IC glue
              by digtalhd
              Hi!
              Anybody help me. Remove IC glue on mainboard.
              Thank you....
              11-08-2024, 02:25 AM
