Id this resistor please
  • landyboy
    • Apr 2013
    • 443
    Trying to ID this resistor not having much luck any help would be appreciated. Thanks
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Id this resistor please
    * Inductor
    Follow the white rabbit.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Picture of board would be interesting.
      Color code is weird possibly indicating inductor, but usually inductors are green...
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        How to calculate inductors :
        http://www.learnabout-electronics.or...nductors04.php
          Can we see the good clear straight shot pictures of the whole top and bottom side of the board?
          • landyboy
            • Apr 2013
            • 443
            I will get some pics of the board today. Its from a Vizio 42". I can tell you it is marked R808D on the board.
              So it is resistor, cannot tel what its function is until I get to see the good clear picture of the board.
              VIZIO model ??????
              Board P/N???????
              • landyboy
                • Apr 2013
                • 443
                Here you go...just a little background. while replacing the cap next to this resistor I damaged the resistor now requiring to replace it as well.
                • R_J
                  • 9581
                  The resistor does look a bit damaged but the value might still be ok, try and measure it.
                  The damage was not caused by circuit failure and seems to be in series with R808A, B, & C from the main cap to the ic802
                  Also knowing what the number is on ic802 might also help
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    These are all GUESSES:
                    Guessed value is: 499KΩ ⅛W (yellow white white orange red?)
                    Guessed purpose for resistor: startup resistor for off-line SMPS
                    Guessed criticality of resistor value: fairly low
                    And agreed, that resistor may still be good, measure its resistance. As it's mechanical failure, it should fail open...
                    • R_J
                      • 9581
                      I would agree 499K, there are 2 other resistors in series, R808A=1meg, R808B=1meg & R808C=499K.
                      I suspect R808C and R808D combined would = 1meg but instead of another surface mount 1meg and a jumper wire, they used 499k a regular 499k resistor to jump across the other traces
                      • landyboy
                        • Apr 2013
                        • 443
                        I must be colorblind lol. I see Blk,Silver,Gray,Brown,Violet.
                        • landyboy
                          • Apr 2013
                          • 443
                          I tested the resistor and I am reading 503 on the 2000K setting.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Nah, the colors have faded due to some heating it seems. We weren't really using color, but judgement from seeing many similar designs.
                            Anyway, 503KΩ is within 1% of 499KΩ, so I think just reinstall that resistor.
                            At the worst the power supply is dead and you know which resistor is bad...
                            • landyboy
                              • Apr 2013
                              • 443
                              Before I removed the small resistor I tried that. First replacing the large cap right beside it. The set would come on and work a while then shut off and the old cap was bulged badly. But as I said I thought I damaged that resistor but did leave it in place at first and the set would not even power up. So I made an assumption that it was bad. Ugg
                              • Techgeeky
                                • Oct 2017
                                • 15
                                • Turkey
                                That one looks like an inductor. That one having a thick body from ends and slim body from the center.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  It'd be a strange inductor since it has an R808D component designator...
                                  As R_J suggested, get us the part number of the IC (IC802) that it's connected to... then might be able to reverse engineer the value...
                                  ... or if someone somehow finds the schematic...
                                  • R_J
                                    • 9581
                                    When you were replacing that cap, and damaged the resistor, Did you remove the 2 screws from the heatsink and bend it back to access the cap, by chance... If you did check the legs on the fet's to make sure they are not broken
                                    Have you ever measured the voltage on the cap ? to see if you at least have 160v or 400v if the pfc is working
                                    • Sparkey55
                                      • Jan 2010
                                      • 1523
                                      In the old, old days Inductors were often called Reluctors. Because coils were "reluctant" to pass a.c. as opposed to condensors that allowed a.c. to pass more freely.
                                      • landyboy
                                        • Apr 2013
                                        • 443
                                        RJ I did not, I worked it without moving the heatsink. I did get a replacement 499k Res and replaced it. Same thing will not turn on. I must have done something. Like I said it would turn on before I did anything but then shut of and that cap was badly bulged.
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • chth96
                                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                          by chth96
                                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                          Since then, This AC/DC adaptor have been out of order.
                                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                          And Is there any possibility that it will suddenly explode as well as to be out...
                                          12-03-2023, 04:40 AM
