EEPROM function confusion
  • nomoresonys
    • 12235
    • U.S.
    #61
    Re: EEPROM function confusion
    Interesting thread, so I can program 25Q32FVSIG with CH341A?
    • SidneyCanadas
      93C46 and 93C56 EEPROM
      by SidneyCanadas
      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
      06-14-2023, 01:16 PM
    • dmccul2698
      Pioneer DEX-P99rs "No EEProm " diagnostic code.
      by dmccul2698
      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
      1). Understand the schematic and check the connections between the EEProm and DSP
      2). Check the functionality of the EEProm
      I don't know if this is the unit's problem but it's a place to start.
      I have little to no electronic experience...
      04-08-2024, 05:32 PM
    • edgarmg15
      Damaged EEPROM on TV Vizio E320-A0
      by edgarmg15
      Hi everyone
      I´m trying to repair a TV Vizio E320-A0 that I found in the street
      The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
      The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
      So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
      11-19-2022, 03:46 PM
      Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
      This is a new item at Electronic GoldMine that has arrived within the last few weeks
      Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
      Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
      https://theelectronicgoldmine.com/products/g28392
      One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
      11-24-2024, 01:25 AM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
