Smart Appliances these days?
  • bogart219
    • May 2009
    • 196
    • usa
    Hey fellows, couple of questions. I have a led on my Fridge that lights up every six months telling me its time to change the water filter. I'm assuming its using a 555 chip or some timing circuit to turn this light on every six months. To turn this led off, you have to press a reset button. I actually change the filter every two years or when I noticed the water flow start slowing down. My Cuisinart coffee maker has a red light light come on when the maker supposedly needs cleaned. I havn't noticed any set time when this coffee maker decides that it needs cleaned. Here is my question. After I go through the cleaning routine with the white vinegar, the red light goes off by its self. I didn't unplug it or reset anything. this is a $50 coffee maker. How did it know if I actually cleaned it or not? What kind of sensor could determine this? Its a model CBC6400-PC. Thanks!
    • 31071
    Re: Smart Appliances these days?
    probably just an led & light sensor.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      its just a thermal switch on the boiler unit.
      when it gets limed up it runs hotter since the heat transfer to the water is impaired.trips the sensor and turns on the light.nice and simple.and useful.
      nothing "smart" about any appliance.
      they are just loaded up with electronic crap.
      • bogart219
        • May 2009
        • 196
        • usa
        Thanks, seems this would be the most logical explanation!
        • jondoe
          • Nov 2016
          • 547
          Don't forget that the water filter has bacteria growing in it constantly, which is the main reason for the reminder to change it, the slower flow rate is of secondary concern. You can end up with more bacteria in the water from the filter than you had coming from the tap in the first place.
          • bogart219
            • May 2009
            • 196
            • usa
            Never considered this. Never noticed a slower flow rate though. Thanks.
