13003 transistors...TO92?!?
+ More Options
Posts
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Ok I think I found another fakey.
    A CFL burned out on me so I opened it... found the tube had both heaters open (weird!!!). Trash time.
    Then I looked at the driver board. I found two 13003 transistors... they're TO-92! Aren't they supposed to be TO126? And yes, the 13003s appear to be OC....
    Oh well, I guess nothing to salvage from this CFL. At $0.50, it's no wonder they cheaped out as much as possible.
    Pictures, when I get a chance...
    • 31111
    Re: 13003 transistors...TO92?!?
    no, you can get them in to92 - i got some from RS for a repair.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Ah okay. All the other 13003's and the datasheet I pulled up has it TO-126 which is what I'm more familiar with. So I suspect the thermal resistance is higher for the TO92?
      Not sure how many watts either can dissipate without heatsinking...
      • redwire
        • Dec 2010
        • 3912
        I laughed when I first saw them, the little guys are popular in CCFL/LED bulbs, 12V 20W halogen lighting and crappy AC-DC wall warts from the gutters of guangdong.
        taiwan MJE13003 is rated 400V 1.5A 20W max. in TO-126 and 1.5W in TO-92.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Ha. that's 20W with a heatsink; without one like in most CFLs - only 1.4W (and 1.1W for the TO-92 in the same situation) - no wonder why they started using TO92, only a little lower limit...
          Granted I have seen dead CFLs with (slightly) heatsinked TO220s... forgot if they died or not.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            It's the same design family as the MJE13005, 13007, and 13009 (the intermediate steps were lower voltage). Originally the MJE13003 was TO-126. I guess the die fits in a TO-92 package and suits a particular low-cost niche. If I were repairing and they fit I'd upgrade to the TO-126 part.
            PeteS in CA
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I suppose so. As it was in a $0.50 CFL lamp, it's not worth to repair it because it suffered multiple failures:
              - both 13003s are shorted C-E
              - both heaters of tube are open
              - both 10 ohm emitter resistors are fried.
              I kept the 0.47 ohm fusible resistor, at least that seems to still be working. The transistors saved the fuse as always.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Too bad they don't use a transistor for the fuse too
                • jrodefeld
                  Asus laptop won't boot (no power) - possible bad caps?
                  by jrodefeld
                  I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                  The model:
                  Asus Zenbook Pro Duo UX582L
                  I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                  However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                  09-02-2024, 04:55 PM
                • RetroComputingGrotto
                  Where Can I Buy Acer and Lenovo USB-C Ports
                  by RetroComputingGrotto
                  I work in UK School so buying things from the likes of eBay is not allowed as it's in our internal financial regulations that we can't purchase things from there.
                  I've had a few USB-C ports that were damaged (2 were completely ripped off the motherboards) due to misuse from the 'little rascals' in our Schools. Fortunately I have some Spares and Repairs laptops that they had damaged/broken in other ways that I could salvage the ports from.
                  I was chatting with someone at Mouser and between us we were unable to find a correct replacement. I'm guessing they're not a generic...
                  09-01-2025, 05:50 AM
                • howardc64
                  Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                  by howardc64
                  Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                  • Backlight on, no image
                  • Disconnect right buffer board (view from front), left side display comes on
                  • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                  • Buffer board is pretty simple
                  Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                  07-11-2025, 04:04 PM
                • spleenharvester
                  Good power bank shells for 18650 cells?
                  by spleenharvester
                  I did a cell salvage run on some Dyson batteries to build out a new fleet of Milwaukee batteries and the yield was a lot higher than expected, so I now have a lot of extra Sony VTC4s that are in reasonably good health. I'd like to build them into power banks, there's a glut of shells for 18650s on AliExpress but I don't know which are any good (read: won't explode). Can anyone recommend some (especially the ones that just fit a single cell)? Weld or weldless are fine, I have a spot welder
                  I suppose USB-PD and/or quick charge would be desirable too
                  Cheers
                  05-11-2025, 01:47 PM
                • spleenharvester
                  Reverse engineering of 18650 4-channel tester
                  by spleenharvester
                  Hi friends
                  I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                  05-04-2025, 02:43 AM
