hy1908 mosfet equivalent
  • petehall347
    • Jan 2015
    • 4427
    looking for equivalent or exact replacement in the uk .. these seem to be Chinese made .
    same as these ...https://www.aliexpress.com/item/10PC...758503553.html
    its for motor control in a hoverboard i just got given to play with .
  • tofik
    MOSFET equivalent K8A60DA
    by tofik
    Hello guys,
    I have a shorted MOSFET K8A60DA with the following characteristics:
    Type Designator: TK8A60DA
    Marking Code: K8A60DA
    Type of Transistor: MOSFET
    Type of Control Channel: N -Channel
    Maximum Power Dissipation (Pd): 45 W
    Maximum Drain-Source Voltage |Vds|: 600 V
    Maximum Gate-Source Voltage |Vgs|: 30 V
    Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
    Maximum Drain Current |Id|: 7.5 A
    Maximum Junction Temperature (Tj): 150 °C
    Total Gate Charge (Qg): 20 nC
    Rise Time (tr): 25 nS
    Drain-Source
    07-19-2023, 05:18 AM
  • dreico33
    AON7403 Mosfet Equivalent
    by dreico33
    Hellow guys,
    I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
    Thank you very much.
    11-16-2024, 09:28 AM
  • Jane
    How do you test MOSFET in laptops ?
    by Jane
    I tried to use this method:
    Testing an N-channel MOSFET:
    Step 1: Discharge the Gate (turn off the MOSFET)
    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
    Step 2: Charge the Gate (turn on the MOSFET)
    Now, place the red probe on the Gate (G) and the black probe on the
    09-27-2024, 03:31 AM
  • mohamed mm
    looking for equivalent mosfet for (IR3598MTRPBF)
    by mohamed mm
    I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
    it's for motherboard ram voltage.
    I hope someone can help me.
    Thank you.
    11-01-2023, 07:28 AM
  • jackx
    equivalent MOSFET 4C09B
    by jackx
    hello brother
    i need equivalent MOSFET 4C09B
    05-27-2024, 03:41 PM
