Best practice - diode mode or powered on voltage testing?
  • caphair
    • Nov 2011
    • 1249
    I'm curious if using diode mode for troubleshooting is faster/easier/reliable compared to voltage testing to locate areas of fault?
    By diode mode I mean, device off, red probe on ground and black probe at inputs/outputs and if meter shows 0v then indicates a short
    Recently I was troubleshooting a Plasma tv and I used diode mode to pinpoint shorted IGBTs on the X main board. Normally I'd power on and check for missing voltages but didn't want to deal with the risk
    Curious on other's input and reasons for how they troubleshoot
    master hoarder
    • May 2008
    • 12175
    Re: Best practice - diode mode or powered on voltage testing?
    If testing PSU outputs, I prefer to just measure the voltage first. Reason being is that you get instant information if the PSU is working or not.
    If measuring the output of a PSU in diode mode, sometimes low-resistance discharge/dummy load resistors (like 47 Ohms or less) can fool you into thinking there is a short-circuit (especially if your meter has diode mode combined with continuity, like many cheap meters do). If not that, sometimes large caps can take a long time to charge in reverse when you place your probes on the PSUs outputs. This means your meter may show a "short-circuit" for several seconds before the caps charge. If you don't wait for that, then you may erroneously conclude that something is shorted when it isn't.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8330
      For me, that would depend on what I am repairing and what the fault is.
      • petehall347
        • Jan 2015
        • 4440
        huntron tracker would be a better way .. one of those things i still need to build .
        • abajor
          A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
          by abajor
          Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
          PPBUS_3GH diode: measures good .45V
          PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
          The weird so far is
          PP3v3_G3H_RTC_X diode: .104V (WTF?)
          PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
          Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
          Not sure what any of this means...
          03-18-2025, 10:27 PM
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Instafixx
          Macbook A2179 820-01958
          by Instafixx
          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
          I checked the Power Sequences below and found this -
          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
          05-20-2023, 05:19 AM
        • echothegamer
          Macbook A1466 dies when charger disconnected
          by echothegamer
          Hello all,
          Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
          Details:
          Macbook 13' A1466
          Board (820-3209-A)
          Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
          Pictures below of Boardview and schematic...
          I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
          It's an older model and it is very likely that battery has become...
          10-28-2023, 12:00 PM
