How to troubleshoot i2c that's held low?
  • caphair
    • Nov 2011
    • 1249
    I'm trying to fix an iPhone that won't boot up.
    This model has two i2c lines (SDA and SCK) the clock line is at a steady 1.8vbut the data line is stuck low at 200mv where normally it's also at 1.8v
    There are multiple chips sharing the same i2c lines including the processor.
    In the past I was able to fix a similar problem by removing each ic sharing the i2c lines one by one until the data line went high again. However it's very time consuming.
    Is there a way to pinpoint the troubled ic without removal of each one by one?
    • 31137
    Re: How to troubleshoot i2c that's held low?
    tie the line to the 1.8v supply and see if anything heats up.
    *but* because the circuits are cmos, it could be running in reverse.
    that is, using a pulldown resistor with the chips taking the line high.
    so you may also find it's an open-circuit in a chip rather than a short.
    if you have the schematics, does it have pullup/down resistors?
    • caphair
      • Nov 2011
      • 1249
      Yes it uses a pull-up resistor already measured it and it's not open.
      At 1.8v applied to that line it wouldn't draw much current to see what's keeping it low by heat I imagine?
      • Syseng
        Lenovo P14s Gen 5 SVP unlock
        by Syseng
        This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
        The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
        06-22-2025, 07:44 AM
      • Ihandyrepair
        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
        by Ihandyrepair
        Hi guys
        I just started fixing 4k TV few months ago. so I am still learning a lot
        I got this tv from friend complaint is ghosting or horizontal lines on image.
        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
        then it started to show the ghosting white image.
        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
        it has 3 thin small boards at the bottom of the...
        12-05-2022, 04:18 PM
      • joelz
        pin Setting parameter line or set lines menu for adding ITE5571e on RT809F programmer
        by joelz
        Hi, sorry if i here to request if anyone know number of pin to set lines for reading ITE7751e on RT809F..i try to see on schematic but i dont know how to choose it..pleasee..
        11-18-2024, 06:02 AM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • DrvLikHell
        Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
        by DrvLikHell
        Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
        The...
        02-05-2025, 01:44 AM
