Solder 80/20 PB/Sn
  • socratez
    • Jun 2017
    • 9
    Solder 80/20 PB/Sn
    I picked this type of solder at the dollar store. Can i use this alloy to hold components to pcb?
    On the wiki, it mentions it can hold radiator fins together. Which is usually copper or aluminum.
    Am I correct that it has a wider temp range to solidify so it can cause broken joints more likely to form if not held steady?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Solder 80/20 PB/Sn
    Normally there is 60/40 Solder for electronic work...Solder does not hold aluminum together.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      Lead is cheaper than tin, that's perhaps why it's at a dollar store...
      I wouldn't use this stuff if I can avoid it. Yes it may stick but you have to be careful as likely you'll get cold joints if you touch it even slightly while cooling and not have clamps to hold the parts steady during cooling.
        • 31294
        80% lead sounds dangerous,
        it may be for soldering metal panels together prior to finishing - like for car body's
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8711
          Well it is used for copper radiators, I'd imagine car bodies are welded not soldered.
          I don't think welding copper works very well in air...
          • petehall347
            • Jan 2015
            • 4450
            car bodies used to be lead filled along the seams . also for filling dents and rust holes .
            copper can be spot welded .
            • socratez
              • Jun 2017
              • 9
              Ok, thanks all. I'm not going to use it.
              • petehall347
                • Jan 2015
                • 4450
                i have been using this spec with no troubles at all ...MBO 0.7mm Wire Lead solder, +183 → +190°C Melting Point, 40% Lead, 60% Tin,
                • socratez
                  • Jun 2017
                  • 9
                  @petehall347, thank you!
                  • R_J
                    • Jun 2012
                    • 9625
                    Just make sure its NOT "acid core" solder
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • corrize
                      Best way to solder LVDS connector for beginner (and qfn) ?
                      by corrize
                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                      See the test :
                      https://youtu.be/bNAzC-EvqHs?t=1767
                      With hot air from bellow the board, that's...
                      03-09-2023, 02:57 AM
                    • petemanuk
                      BGA solder balls not connecting - help pls
                      by petemanuk
                      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                      11-16-2022, 05:21 AM
                    • myth77
                      UV solder mask - high temp resistent, recomendation?
                      by myth77
                      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                      Is there any solder mask...
                      03-28-2022, 04:04 AM
                      Multifix 425-01 and 450-01 Rework Flux Datasheet
                      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                      - No Clean Formulations
                      - Low residue
                      - Range of activity to deal with different component solderability
                      - Halide free
                      - Suitable for dispensing
                      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                      Both products are supplied in syringes or cartridges for application by dispensing....
                      10-07-2024, 06:02 AM
