Which source is good for Yaseu/Vertex VX-10's charger?
  • Jackoo
    • Apr 2017
    • 8
    • Pakistan
    I have read somewhere that Batteries America is a good source for that, any recommendation from your side?
    Here is a good used source for 18650 batteries
    Here is a website I have ordered from before and the results that they claim are correct from what I have seen from the batteries I have bought from them
    BatteryHookUp.com
    https://batteryhookup.com/collection...odem-batteries
    I have test about 5 battery packs ( out of 15 battery packs I bought) and have had very good results and so far have not found any bad cells
    I have also bought these battery packs before on EBay and they are a good source for a battery case that holds 18650 batteries however...
    06-25-2021, 05:05 AM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • Johndill
    Dell Inspiron 7567 LA-D993P odd charger issue
    by Johndill
    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
    Here are the tested scenarios:
    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
    2. With the laptop off, plug in charger (LED says on) & the front charging...
    11-16-2022, 10:55 PM
