HP Omnibook XE3 - DC Power Jack Broken
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    I require to replace the jack in one of these notebooks.
    Can anybody supply me with a part reference number or such like?
    The jack is a 2.5mm type
    The PSU (HP F1451A) used with the laptop states;
    O/P 19V @ 3.16A
    Any help appreciated
    Thx
  • valvashon
    Samsung UN55FH6030CXZA main board USB jack indentification
    by valvashon
    Samsung UN55FH6030CXZA main board, BN41-01894, bad USB jack. Jack is mangled and needs replacing with like. Jack is marked "Simula" with the number 130318. Search for Simula turns up a weak looking website of a company that seems/seemed to supply USB jacks and other USB technology but no current items turn up for sale.
    I should be able to research and find something applicable through a Digi-Key search after I unsolder/cut out this one and measure the mounting/pin connection pattern on the board but I thought I'd ask here to see if anybody knows of an exact make/model...
    01-23-2025, 11:17 AM
  • magneh
    HP Pavilion 23 All In One - Broken DCIn jack and SIO
    by magneh
    Hello guys
    This is an old device from a friend.
    DC jack was broken, and I figured that SIO was also KO.
    Replaced SIO and DCjack, and DCin LED is now ON again
    But when pressing power button, nothing happens.
    Does the SIO needs to be programmed? ITE IT8518E
    Thanks for any inputs....
    03-14-2022, 10:22 AM
  • chth96
    Is it possible bridging tiny broken trace
    by chth96
    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
    cutting tiny trace.
    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
    12-03-2022, 11:32 PM
  • paparazzo79
    3.5 mm headphone jack missing
    by paparazzo79
    Hi guys,
    I purchased used MSI GE 73 Raider laptop used from a guy.When laptop came home I noticed that there is no "golden circle connector" on the headphoner jack (pic below).
    I contacted the seller, he told me like it was there and it probably fell off.
    I am not dumb, is he lying to me or it is possible that in the shipping it really fell off?
    Oer laptop is missing whole connector.
    The headphone jack works normally,I have tested it with headphones....
    05-20-2025, 08:48 AM
  • diamon
    Dell 5590 LA-F412P does charge with USB-C not with DC-Jack
    by diamon
    As mentioned, I have a Dell 5590 laptop with motherboard LA-F412P.
    This laptop works with the USB-C charger and not with DC-Jack charger.
    With the USB-C charger attached, the battery is charging and in the BIOS the charger is also recognized.
    With the DC-Jack charger attached (USB-C charger removed), the light of the charger is not going off and the BIOS does not see the charger (message AC Adapter = Not installed). I'm using original Dell chargers and I have tested the used chargers on other Dell laptops and they are working correctly.
    I have replaced the DC-Jack,...
    12-29-2023, 07:29 AM
