Super Glue
  • capwizard
    • Jun 2016
    • 1991
    Super Glue
    Accidently I cut my finger from the sharp edge of the LED screen metal case when I was changing LEDs. I'm using Super Glue?
    Super Glue for Wound Closure
    http://www.realfirstaid.co.uk/superglue/
    Is super glue toxic?
    According to the United States National Toxicology Program, the inhalation exposure toxicity rate of of ethyl cyanoacrylate, or super glue, is safe and additional study is unnecessary. The report also highlighted an extremely large LD50, with over 5000 milligrams per kilogram of body weight required for a lethal dose.
    THE COMPLETE GUIDE TO USING SUPER GLUE FOR CUTS
    http://morethanjustsurviving.com/super-glue-for-cuts/
    Super Glue : Super pegamento
    I cut myself. : Me corte.
  • petehall347
    • Jan 2015
    • 4430
    Re: Super Glue
    it was invented for fixing cuts in the skin ..i use it all the time no problem
    • capwizard
      • Jun 2016
      • 1991
      Re: Super Glue
      It is sad to say I use super glue instead of Band-aid. So, I can go back to work immediately.
      I can go back to work immediately. : Puedo volver a trabajar inmediatamente.
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        Re: Super Glue
        REALLY? You use Super Glue to fix wounds?
        Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
        1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
        • capwizard
          • Jun 2016
          • 1991
          Re: Super Glue
          Yes, after sterilized, If it is a big wound use staples. My wrose work injure is I push down my palm on table with solder iron, it took 3 months to recover, I wish it was unplugged.
          • RukyCon
            A Fake Rubycon
            • Jan 2017
            • 816
            Re: Super Glue
            Originally posted by capwizard
            My wrose work injure is I put my palm on solder iron, it took 3 months to recover, I wish it was unplugged.
            That must have hurt a lot.
            I'm not a expert, I'm just doing my best.
            • televizora
              ghettomodmaster
              • Nov 2016
              • 957
              Re: Super Glue
              Usual general purpose Super Glue uses acetone as an solvent. From where comes the bad smell of the open bottle of this glue? How do you think?
              There is special medical glue, that doesn't use acetone as an solvent, but ethanol.
              It's stupid, stupid, stupid to use general purpose Super Glue.
              p.s I have no idea why you are writing in Spanish as well.
              • capwizard
                • Jun 2016
                • 1991
                Re: Super Glue
                First, I saw people did that, my reaction just like you.
                I try one time and it is better than any medical Band-aid or First Aid Spray which won't stop the blood flowing out, but super glue stop right there instantly.
                This is no joking, that is a life-saver. Everybody should try it at least one time. My wife taught me that, She is a certified caregiver.
                • shadowpool
                  • Mar 2017
                  • 6
                  • US
                  Re: Super Glue
                  I've used it on a pretty nasty cut before because I was unable to get to a hospital. It worked out pretty well with no scarring. The regular stuff is a little irritating and can burn. The medical formulations are supposed to be more pleasant. You never know what additives they stick in the regular super glue so I'm not sure if I'd use that for everyday cuts.
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    Re: Super Glue
                    I tried it once but I couldn't get the band-aid off when it healed up.
                    sigpicThe Sky Is Falling
                    • capwizard
                      • Jun 2016
                      • 1991
                      Re: Super Glue
                      Ha-ha
                      • RukyCon
                        A Fake Rubycon
                        • Jan 2017
                        • 816
                        Re: Super Glue
                        My father used super glue to close up a head wound that i suffered when i was younger.
                        • capwizard
                          • Jun 2016
                          • 1991
                          Re: Super Glue
                          He hit you with stick has nail on it?
                          No wonder You're so smart.
                          • RukyCon
                            A Fake Rubycon
                            • Jan 2017
                            • 816
                            Re: Super Glue
                            • Destroyer-Br
                              [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                              by Destroyer-Br
                              I'm working on an Acer Nitro 5 unit with the following specs:
                              • Motherboard: LA-J871P Rev: 1B
                              • Model: Acer AN515-55-59MT
                              • S/N: NHQ7JAL00403906A973400
                              • SNID: 03902728734
                              Initial Issue
                              The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                              After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                              04-17-2025, 08:18 PM
                            • mitsu2k
                              The Real Dangers of conductive glue.
                              by mitsu2k
                              I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                              Here is an experience I...
                              04-16-2023, 06:29 PM
                            • ongobongo
                              Asus ROG Ally - Super IO Chip replacement
                              by ongobongo
                              anyone here who has experience with replacing the super IO chip of an ROG ally?
                              I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
                              Ongo
                              11-17-2024, 11:27 AM
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • Loki_Fido
                              Clean ME for VAIO please. Super I/O just got replaced
                              by Loki_Fido
                              Hi ya folks,
                              Hope everyone's having a nice day.
                              I recently replaced the super I/O chip and now I believe i need a clean ME for the system to come online. Cause i started the laptop and it did not start.
                              Laptop details
                              Sony VAIO
                              Product name VJS111
                              Model Number VJS111D12N
                              Serial Number 7014633
                              Motherboard markings
                              FEILONG MB REV 1.03B
                              UMT-KS 2V 94V-0 E49068 A7 1545 07-01
                              Original bios file attached
                              SUPER I/O chip model ITE IT8528VG
                              Thanks a million in advance folks...
                              05-11-2025, 11:40 PM
