TV repair Data base!
  • capwizard
    replied
    Re: TV repair Data base!
    Look at 6:16 the current chart signature of the front load washing machine. At 7:38 the detail current chart of the gas furnace. At 8:24 they know the furnace ignition system is falling. They have same idea as me. Now they are expanding the library of home appliances. How is about TV repair Database!
    Future House | Smarter Home Electrical Metering
    https://www.youtube.com/watch?v=HZft4qoK7Ds
  • capwizard
    replied
    I No understand French at all, Un poco de espaƱol. It's nice of you translation: there are cheap processors that can take the needed measurements and compare it to a Database in its memory , and here , we don't need high end processors capable of millions of operations in a second , all what we need is a low end processor with some sufficient ram.
  • jiroy
    replied
    Originally posted by capwizard
    ....Ding...... Dong......... you have a message...."Dear jiroy : Hello, My name is Jasmine, I is your Princess, the TV in the living room. Today I does the routine self diagnostic, I finds out SBY 5V is at 4.5V, before I is dead I will WIFI you the last message. ......and all the informations about me You can use Data logger to read it out after I has no power ..........Love you."
    (In 2020, The Law requires Robots use only Third person singular. EX: I is...I works...Master, I is fine today.........To belittle Robot's identity, depreciate Talking -Computer is never A Human Being. You can't mistreat animal except Robot. Toy Robots are made for human pleasure purposes only and you can torture them or Beat 'em.) ........................................This is my fantasy...................
    If Trump likes... All TVs sold in the United States are required to use the wifi OBD.
    OBD (On-board diagnostics):
    1996: The OBD-II specification is made mandatory for all cars manufactured in the United States to be sold in the United States.
    PS: There have been reports of thieves using specialist OBD reprogramming devices to enable them to steal cars without the use of a key!
    Chip on Board
    https://www.youtube.com/watch?v=Orw_FF1sjbw
    PCB,COB chip auto sealing machine
    https://www.youtube.com/watch?v=NpCXm65VQXI
    Capwizard; I studied this idea carefully from different sides , and i find it completely applicable and can be done fairly easy , within some acceptable prices margin . Even Princess Jasmin 2 won't feel a princess , lol .
    First of all , in respect of your wish to keep the device an external one , meaning without opening the tested appliance , you'll have to disregard certain methods that can be useful too , like odor sensors for some overheating elements or light sensors to record the instant of a blowing part , etc , but you can also add them in "Princess Jasmin 2 Professional Edition" .
    Talking about some details , the French article "EPISODE 15 : Anatomie d'un processeur A.S.I.C. (French) > Anatomy of an A.S.I.C. " . La pucelle ou le mini processeur utilisee dans la calculatrice est peut etre une acceptable solution , le prix d'un tel pucelle est pratiquement negligeable ..
    Meaning , there are cheap processors that can take the needed measurements and compare it to a Database in its memory , and here , we don't need high end processors capable of millions of operations in a second , all what we need is a low end processor with some sufficient ram .
    Talking about what the database issue , this can be highly accurate in many cases where the TV , for an example is still lit , showing irregular symptoms of different errors . Even when the TV isn't lit , there are also cases where your processor can check an Amperage value .
    To make a Database easily , reliable and sufficient ,an Amperage testing should be done on a new TV , while creating situations where temporarily missing component or components , and next those are registered in the Database . All what the processor has to do when a real error occurs later , is comparing his database to the related erroneous readings .
  • vinceroger69
    replied
    Easy! Modify the firmware, If warning lights on the dashboard is on, the car's speed is not allowed to exceed 40. If tire sensors found a big leaks or a flat will use ABS slows down the car or you can't start the car. and said " Sorry, my Master, I is fine! but I could not let you drive the car until tire is changed.... BTW... all the Curse Words I does not understand. Have a nice day. "
    a fair few uk cars have this already when theres a fault and the ecu picks it up and puts the engine managment light on it reduces the car speed and limits the rev range called limp mode its a good idea to be honest.
  • capwizard
    replied
    Easy! Modify the firmware, If warning lights on the dashboard is on, the car's speed is not allowed to exceed 40. If tire sensors found a big leaks or a flat will use ABS slows down the car or you can't start the car. and said " Sorry, my Master, I is fine! but I could not let you drive the car until tire is changed.... BTW... all the Curse Words I does not understand. Have a nice day. " .............
    replied
    Yeah, so your tire went flat all the suddenly so you roll over any way because it is too late but hey you see warning lights on the dash while you laying in pain. Most people ignore all kind of warning signals they see on the dash board any way and think 'I will deal with it later!'
  • capwizard
    replied
    flat tire sensors are A good mandate from government, It's prevent the SUV rolled over.
    True Story : One TV shop owner's wife, She has tattoo on the arm, I said " Ah, you must be pretty wild when you were young.", she said " that tattoo is my son's portrait who passed away on Ford SUV rolled over." I was shocked said " I'm sorry to hear this unfortunate story.".................
  • capwizard
    replied
    The TV video processor already has Logic built-in self-test (or LBIST)
    Sony TV self-diagnostic LED code :
    01 - reserved
    02 - over current protection
    03 - over voltage protection
    04 - no vertical sync
    05 - IKR error at power on
    06 - I2C bus lines low at power on
    07 - NVM no I2C acknowledge at power on
    08 - horizontal protection
    09 - tuner no acknowledge at power on
    10 - sound processor error
    11 - reserved
    12 - scanrate error
    13 - DAC error
    14 - backend error
    15 - dynamic convergence error
    16 - PIP error
    The Newer TV can use wifi sent out error code to owner, or hook up laptop to diagnose the problems.
    PS: If government menand to do the TV OBD, TV manufacturer can upgrade the TV firmware in no time.
  • diif
    replied
    Surely better to mandate a decent warranty period forcing manufacturers to improve build quality ?
    Adding sensors for everything as well as some sort of control unit adds unecessory manufacturing costs.
    Whatever the increase in cost its always passed onto the manufacturer.
    Consumers generally want cheap.
  • capwizard
    replied
    Look this Bluetooth V2.1 mini OBD2 Scanner I had, $ 2 -3.00, can connect to your cellphone, will show a lots informations of your car. Before the TV OBD come true, this Bluetooth current sensor is an alternity.
    Buy Cheap#13 Mini VGate Scan ELM327 Bluetooth V2 1 OBD2 OBD II Auto Torque Scanner tool B fromeBay
    https://www.youtube.com/watch?v=iYD_EkeQtrI
    Bluetooth OBD II Tutorial [Super Mini ELM327]
    https://www.youtube.com/watch?v=WOQLh1iGN60
    Review ELM327 OBDII Bluetooth Adapter with Torque Android App Demo test - Dealextreme DX
    https://www.youtube.com/watch?v=3FKdNYavIcQ
    Review of Bluetooth OBD2 Wireless Transceiver Diagnostic Dongle - Check Engine Light
    https://www.youtube.com/watch?v=XdAd3MtK6lQ
    replied
    "If Trump likes... All TVs sold in the United States are required to use the wifi OBD." that is what we need, more government mandate.
    How about the cell phone, home appliances, HVAC and so on and on, and who is going to pay for it? Look at what they do with the money they collect for the so called R-Waste fee.
    BTW, look into flat tire sensor, $150 or more each when they get damaged and MUST be replaced.
  • capwizard
    replied
    Chip on Board
  • capwizard
    replied
    We can't fix all the TVs, the one could not fix, is the one from another shop or it is worth the time to dig in or pay the tips for.
    My body and I paid $500 for repair tips collections from (Tvmans tips collections (Florida), 10 series hard-copy books), 10 years ago.
    PS: Why need to sell the current device? The software need to pay for people to write it and to maintenance, it will need more HDD for the Web server's Database with faster and accurate service for general public.
    PS: I don't mind pay for the tips is useful to me. Actually I am begging for it!
    replied
    I already did! Some tips it worth $280 or more for me! because I can use again and again.
    But that is not based on what you want the customer to do to provide the reading result from the tools you suggested for them to use to HELP you.
    We all have done that repeat problem fix, the first time you see th problem which may take you hours or days and not really making money on the first one, but the next time you see the same make and model, then it is just a matter of putting in the new part or resolder commonly failed solder joints on particular board, that is when you make money on the next 2~ to how many repair on the same model, been there done that, same model tends to have same failure symptom that is why MFG has service bulletins.
    replied
    "already spent 10 hours help people fixed the problem" Yeah, some time that is due to the asker does not even know to properly read the display on the meter.
  • capwizard
    replied
    I already did! Some tips it worth $280 or more for me! because I can use again and again. and for TV module repair service center (PTS....) it is worth $ thousands......
    PS: Every customer came in, I show them the current meter, To proved it is not the fuse or buttons which they always thought It was!
    replied
    Why don't you try that at your repair shop and see what happen?
    See if they are willing to buy all those tools.
  • capwizard
    replied
    Only this one, then connect to your cell phone. that is all. No buy, no support!, because we don't know what are you talking about!
    PS: Over the Badcaps.net the same TV problems repeat again and again, with this current chart Veterans can work on more rare problems and not waste time on the same problems......with the TV current chart Database we will know who already spent 10 hours help people fixed the problem....move on next one................and get pay..............................
    replied
    It is a current detector, current sensor very simple drive . Most parts are the sofewares, which is on the APP for cellphone to collect data and sent to Badcaps.net.
    PS: "I could have made lots of money on this thread..." Yes.... Your knowledges Worth More than the Money.
    So the customer has to get that board, current sensing resistor, power supply, box for safety, outlets, power cord, etc. do you think the customer is going do that?
  • capwizard
    replied
    alternating current measurement using pic microcontroller
    http://microcontrollerslab.com/alter...icocontroller/
  • astroboypaul
    Surface Book 2 Performance Base dead
    by astroboypaul
    I'm working on a Surface Book 2 performance base (M1032224-004 on white sticker) and would love for some help troubleshooting or where to look next.
    The tablet when not connected to the base seems to work fine, but:
    • When tablet is off and connected to the base, it won't turn on.
    • Connecting tablet that is already on to base there is a windows device detected tone (not sure what device), but tablet remains in tablet mode, keyboard/trackpad don't work, and windows continues to report only 1 battery.
    • Charger white light turns on when connected to the base, but base battery and tablet
    04-25-2025, 12:40 AM
    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
    by sam_sam_sam
    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
    I tested the battery cells there are installed right now and they are testing good with no issues that I...
    02-04-2025, 08:08 PM
    HP EliteBook 850 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
    This specification for the HP EliteBook 850 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Samsonite Base Boost boardview and 850 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-06-2024, 09:00 AM
    HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
    This specification for the HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + Samsonite Base Boost boardview and 1030 G3 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
    HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
    This specification for the HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 440 G1 + Samsonite Base Boost boardview and 440 G1 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
