Full wave rectifier vs bridge rectifier?
  • capwizard
    • Jun 2016
    • 1991
    Re: Full wave rectifier vs bridge rectifier?
    This car Amp I use my PoorMan's ATX power supply keeps cutting off the ATX power supply. I will need more current for start up the Car Amp.
    PS: In the picture show 0.2A but the surge current keeps on cutting the ATX power supply? With the one I just fixed, Amp. works flawlessly?
    • petehall347
      • Jan 2015
      • 4428
      • United Kingdom
      try NTC resistor to slow down power up .
      this might be interesting ..http://nevarllajf.com/daniel/?page_id=44
      • capwizard
        • Jun 2016
        • 1991
        "two large 5W, 10 ohm resistors in series with the positive and negative supply, after the rectifier bridge. Over each resistor, a relay was added." Good idea!
        My Poormans ATX power supply 12 v rating is 14A, maybe the ripple protection circuit too sensitivity.
        PS: Look this one 12v 150A. (pic1)
        Sneak Peak – Ultra Products 2000W ATX Power Supply
        http://www.legitreviews.com/sneak-pe...lIkhrsdMmVO.99
        • petehall347
          • Jan 2015
          • 4428
          • United Kingdom
          my room heater is 2kw
          better to use atx to keep car battery charged up .. then amp should always start up if you dont run it for long
          • capwizard
            • Jun 2016
            • 1991
            Very good idea, I Can put three 18650s or any small 12v battery connects to the 12v output terminals of the ATX power supply, acts as A big capacitor to absorb the surge current.
            • petehall347
              • Jan 2015
              • 4428
              • United Kingdom
              #26
              car amps are expecting a large reserve supply . big capacitor might do it or lipo battery ..
              atx supply is weak link here .. be gentle with it ..keep the bass down and use high ohm speakers . i used to run everything from 12v for years then i got mains supply again .. 48v supply is much better .i will go for that if i lose mains again .
              • capwizard
                • Jun 2016
                • 1991
                "i used to run everything from 12v for years" .....wah..........You live off grid, with Solar or RV mobile home?
                  Originally posted by capwizard
                  To eccerr0r: my next project is the 40A 12v or 96v 5A (lots combinations) power supply. it needs eight 12V 5A AC Adapters, I still collect them. It is A Universal AC Adapter Modular Power Supply.
                  PS: Use four 12v 5A AC Adapters (up to 12v 20A) can replace the one I just fixed.
                  You just do not tie the output of all the supply together:
                  http://www.keysight.com/main/editori...0.00&id=520808
                  https://www.eeweb.com/electronics-fo...rallel-problem
                  Just do some research first!
                  • petehall347
                    • Jan 2015
                    • 4428
                    • United Kingdom
                    #29
                    mobile home ..converted bus to be exact . 1956 bedford . my inside lights are 12v . only have a small solar panel .
                    • capwizard
                      • Jun 2016
                      • 1991
                      Half Self-Sufficient Living is next project for me.........wifi.....an hour drive to Walmart and Home Depot is A must..................
                      Did you know… it is a lifestyle for many people today and... the way things are looking... it may become a norm of our future?
                      Self-Sufficient Living-15 Ideas to Improve The Quality Of Life
                      http://theselfsufficientliving.com/1...cient-in-life/
                      50 Resources To Help You Become More Self-Sufficient
                      http://www.naturallivingideas.com/50...lf-sufficient/
                      • capwizard
                        • Jun 2016
                        • 1991
                        Thank you again , It is not as easy as I thought! Using microcontroller ADC controls monitoring each power supply cc/cv then each AC Adapter needs have digital control CC/CV.
                        Because of Load balancing............. 2 low-value resistors (like 0,1 ohm) in series with each power supply and connect then after the resistors to balance the currents through the 2 PSUs…
                        Basically, if one of the power supplies will go into constant current mode [CC] then if you set it’s voltage slightly higher than the other one, the supply that is set to the lower voltage (say 12.0V) will regulate the voltage, and the other supply (set to, say 12.1V) will go into CC mode and simply supply the rest of the current required (because, it will supply it’s maximum current (or if it has a current adjust, then it will supply the current it is adjusted to)).................the diode idea might work
                        So we make isolate the two power supplies output using a high current schottky diode in following manner.
                        remote sense, CV or CC mode, even analog programming. Auto-tracking allows multiple supplies to track the master, the slaves can have the same output characteristics or can be configured to be proportional to the master.
                        • zx8401
                          Phantom Fiddler
                          • Aug 2013
                          • 49
                          #32
                          That output stage is a bit naughty, no seperate emitter resistor for each transistor, the transistor with the best gain will be working harder than the rest :-(
                          • petehall347
                            • Jan 2015
                            • 4428
                            • United Kingdom
                            #33
                            is this a good time to mention a curve tracer ?
                            • larkesm
                              • Oct 2018
                              • Poland
                              #34
                              This is the name of Graetz bridge construciton of placing the rectifier diodes in curicuit to have bridge diode and this is full wave. The rectifier theary goes here https://911electronic.com/rectifier-diode/
                                HP Pavilion Wave Pavilion Wave Desktop - 600-a103na Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a103na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a103na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a103na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                09-12-2024, 02:00 PM
                              • Steph.hen
                                Bridge rectifier identification part number KPB305G
                                by Steph.hen
                                Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                08-29-2024, 09:52 AM
                              • mpn78
                                Fujitsu Q556, What capacitor for bridge rectifier?
                                by mpn78
                                Hello
                                My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                Thanks....
                                04-05-2022, 12:31 PM
                                HP Pavilion Wave 600-a102ng Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                This specification for the HP Pavilion Wave 600-a102ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a102ng boardview and Pavilion Wave 600-a102ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              • EasyGoing1
                                Reading input and output of bridge rectifier on the same scope?
                                by EasyGoing1
                                I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                06-26-2022, 12:52 AM
