Dell
  • capwizard
    • Jun 2016
    • 1991
    Dell
    Dell laptop no power but AC adapter is good.
  • capwizard
    • Jun 2016
    • 1991
    Re: Dell
    Contains dirty pictures for Adults Only!
    "Some viewers may find this disturbing, viewer discretion is advised".
    YES, it still Alive........W...Why youre eating popcorns? ..Because cockroaches they are my (body) help me make more money............
    • petehall347
      • Jan 2015
      • 4430
      Re: Dell
      there are bugs in the system ...
      did you know that is why that saying came about ? was from valve computers in the old days ..
      • capwizard
        • Jun 2016
        • 1991
        Re: Dell
        Colossus? Cockroaches's meat grinder. ..............S.ss..stop......How could I have my steak dinner tonight!.....................
        PS: Can I fix it? Most of time the answer is YES.
          Re: Dell
          Bug.
          http://americanhistory.si.edu/collec...ct/nmah_334663
          http://www.computerimages.com/musing...uter_bug.html#
          • capwizard
            • Jun 2016
            • 1991
            Re: Dell
            A American's bug: Mark II computer at 1947,
            A British's bugs: Mark 1 1943. Colossus was the world's first programmable electronic digital computer. British codebreakers used Colossus to help to read German coded radio messages during World War II.
            The first machine, Mark 1, worked in December 1943. It solved its first problem at Bletchley Park on 5 February 1944. Colossus Mark 2 was even better. It first worked on 1 June 1944, just before the Normandy Landings on D-Day.
            PS: "Colossus" used many vacuum tubes (valves).
            PS: Mark I was designed in 1937 by a Harvard graduate student, Howard H. Aiken. It that possible US helps UK build the Mark 1 and 2 to codebrake Germans code? Anyway, We are bodies in WWII.
            http://sites.harvard.edu/~chsi/markone/about.html
            • capwizard
              • Jun 2016
              • 1991
              Re: Dell
              For $60 this picked-up, windows-7, Combat Bait-attached, Dell works OK.......................
              PS: The solvent is Acetone. Yes, toothbrush was mine. single Phillips 1 screwdriver bit with Makita electric drill opened all the Dell in no time.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
              • F R 2568
                Dell Latitude 5420 does not start (no post) need help to find the reason why
                by F R 2568
                Hello all,
                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                If the laptop is only connected to the AC adapter (battery removed):
                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                The power/battery...
                01-08-2025, 05:45 AM
              • diamon
                Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                by diamon
                I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                Pictures of these boards:
                Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                Dell...
                02-28-2024, 12:51 PM
              • lalle-
                Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                by lalle-
                Hello!
                I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                08-11-2024, 02:01 PM
