Repairing superfine wiring
  • pentium
    • Mar 2006
    • 2778
    I ended up with a Sony PMW-EX3 that was in a pretty nasty fall. At this point I've repaired everything but the wire harness that brings video to the LCD viewfinder. It's this bundle of several dozen wires 0.3mm in diameter that has one clearly broken wire and several others either questionably intact or with damaged insulation. I can splice them but I have no idea how to insulate the repairs.
    The smallest shrink tube I have only reduces to about 0.8mm and wouldn't work. The harness can't have the wiring completely replaced due to the special crimped ends and so far the best I've gotten out of Sony is that they no longer sell replacement parts for this model camera anymore.
    Find Nedry!
    Check the Vending machines!!
    • 31259
    Re: Repairing superfine wiring
    paint it with flexable plastic glue.
    • chevyquick
      • Aug 2014
      • 5
      • united states
      Brush- On Electrical tape. It's made by Blue Magic.
      • srhofmann
        • Aug 2016
        • 135
        • usa
        Plasti-Dip or water based acrylic paint mixed with elmers white glue
        • mariushm
          • May 2011
          • 3799
          Investigate if it would be possible to use flat flex cables .. solder the wires to the ends of the ribbon cable (possibly cut in several less wide segments and stacked on top of each other)
          Here's an example ... about 3$ for a strip with 23+ wires, 0.3 mm pitch: http://www.digikey.com/products/en/c...t+ribbon+cable
          • Agent24
            I see dead caps
            • Oct 2007
            • 5082
            • New Zealand
            Get smaller heatshrink?
            http://www.mouser.com/ProductDetail/...FIT50028-NA112
            -David VanHorn
            • pentium
              • Mar 2006
              • 2778
              From what I'm reading there I think that doesn't shrink small enough.
              Find Nedry!
              • Agent24
                I see dead caps
                • Oct 2007
                • 5082
                • New Zealand
                Are you sure? Says 1:5 ratio. I think the maximum size spec is just worst case scenario?
                -David VanHorn
                • cpt.charlie
                  • Sep 2013
                  • 270
                  • Spain
                  Some nail paint might work, i've used it to protect some components form corrosion.
                  • petehall347
                    • Jan 2015
                    • 4445
                    can you not run new wires instead of repairing them ?
                    • pentium
                      • Mar 2006
                      • 2778
                      No the ends are crimped and so small that trying to pry it back apart is going to open a can of worms.
                      Find Nedry!
