Modifying a Blood Pressure Pump to Switch an LED
    20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
    by sam_sam_sam
    I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
    At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
    Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
    04-09-2023, 08:04 PM
    ZD-915 vacuum pump motor mount service alert
    by sam_sam_sam
    If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
    One note this unit has been repaired already once because of switching power supply regulator ic chip failure
    Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
    The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
    09-19-2021, 02:15 AM
  • Dannyx
    Remote pump control ideas.
    by Dannyx
    Good day folks. A task was given to me to redesign the control system for a pump system in a remote location. The idea is that there's a tank which has a float or some sort of switch/sensor to detect when it's full/empty and this runs some pumps accordingly. The trouble is the pump and the tank are like 4km apart, from what the chap who inspected them on our behalf told me, so the way this currently works is by using some unknown boards based on SIM cards (see the pictures). From what I can assume, when a contact closes at the "client side" (the tank), it calls up the "server side"...
    09-11-2020, 04:10 AM
  • Dannyx
    Another water pump automation project (suggestions ?)
    by Dannyx
    Good day folks. Some of you may recall that a while ago I was struggling to put together what I considered to be a very basic automation for a water supply system. It didn't work out the way I intended and I learned my lesson to do it properly from the start, rather than try to reinvent the wheel and patch something together myself from scratch, so I'll stick to commercial alternatives for future projects and such a project just came in today !
    This one is easier simply because this time the pump and level sensors are in the same place, so they don't require a remote connection....
    07-26-2022, 11:39 AM
  • betmen
    water pump Scala2 - electrical diagram
    by betmen
    Does anyone have a wiring diagram for the pump mentioned?
    The markings on the board are 98800964 r07, two or three capacitors are burnt.
    I don't have the board with me yet, but I don't know if the printed lines on the board are visible due to the short circuit that occurred and how the capacitors were connected.​
    05-22-2025, 02:56 AM
