TV volume too low?
  • capwizard
    • Jun 2016
    • 1991
    TV volume too low?
    One 80 years old man, saying his, then he put out a piece of paper, Toshiba TV sound too low. I reply " its not A common problem on TV!"......he said "what u say"..."what u say" I say " the speakers are tiny so ull need external amp or soundBAR.".... "wat u sayin"... "wat u sayin" ............it's hard for me to say " you will need A Hearing Aid"........
  • benni
    • Jan 2017
    • 17
    Re: TV volume too low?
    For the sake of his neighbours, a hearing aid is probably best, if not both!
    • capwizard
      • Jun 2016
      • 1991
      For the sake of his neighbours, a hearing aid is probably best, if not both!..............he live in adult community, his neighbors cant hear nothing........
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        What! What did you say?
        sigpicThe Sky Is Falling
          • 31170
          i said "FIRE!", oh never mind - i'm off.
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            What? What? Damn kids and there mumbling, never seen such mumbling people in my life. Goldarnit there's them kids in my yard again, HEY, YOU KIDS GET OUT OF MY YARD! Probably'll have to call the cops on them.
            • karthur
              Vizio D65x-G4 Volume changes on its own
              by karthur
              On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
              It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
              06-05-2025, 08:13 AM
            • crackedprint
              Sony HCD-HX80R Amplifier Volume Control Problem
              by crackedprint
              I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
              I have tried a Cold Reset as per the service manual.
              I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
              I have looked all the way through the service manual and tried many online...
              01-21-2025, 12:18 PM
            • BigOof
              Marantz SR5007 popping on volume change and mute in Direct Mode
              by BigOof
              I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
              12-12-2024, 06:15 AM
            • Storyteller12
              Samsung Soundbar Q900T Cuts Off if Volume above 30
              by Storyteller12
              I have this soundbar and when I turn it on it works until I turn the volume above 30.
              Then the display show “PROT” protection and shuts off.
              I can turn it right back on and it works until volume hits 30 again.
              There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
              I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
              It will play fine for hours with volume...
              03-21-2023, 12:31 PM
            • redwire
              Onkyo TX-SR607 replacement volume control encoder
              by redwire
              I had an Onkyo SR607 with a volume control encoder not working, turning the knob up the volume number would move around crazy and not work reliably.
              Took it out and apart and no, it's not oxide or cleaning, lube required etc.- the metal is simply worn out. It's a 30mm part with metal bushing.
              Volume control encoder Onkyo P/N 25065655W, Alps EC12E2425 is some oddball variant I could not find. I did the dig and tried replacement part Alps EC12E2420803 and it works/fits just like the original. Mouser 688-EC12E2420803 for $3.00
              09-09-2022, 08:59 PM
