Homemade soldering paste, flux & Chip Quik
  • capwizard
    • Jun 2016
    • 1991
    Homemade soldering paste, flux & Chip Quik................
  • capwizard
    • Jun 2016
    • 1991
    Re: Homemade soldering paste, flux & Chip Quik
    A soldering flux : I've been used Organic fluxes for 6 years, I collect pine tree rosin+alcohol +Lard or tallow then mixed it .
    One of the early fluxes was a mixture of equal amounts of rosin and Vaseline. A more aggressive early composition was a mixture of saturated solution of zinc chloride, alcohol, and glycerol.(add some acid, u can make dynamite ).
    B soldering paste : Every time you clean the soldering sucker, keep the debris, Add some A . Now u have homemade soldering paste.
    C Chip Quik: A fusible alloy is a metal alloy as Rose's metal, Field's metal & Wood's metal. The most important element is Bismuth. mix with B with D get C Chip Quik.
    D
    5g 99,9% Bismuth Metal Powder in glass vial - Pure element 83 sample
    http://www.ebay.com/itm/5g-99-9-Bism...kAAOSwWnFV-rLW
    Rose's metal consists of 50% bismuth, 25–28% lead and 22–25% tin. Its melting point is between 94 °C (201 °F) and 98 °C (208 °F).
    • bohaboha
      REAL OR FAKE SOLDERING PASTE
      by bohaboha
      Hello everyone today I see this advertisement about a soldering paste that is according to them video posted as almost fantastic for all surface soldering to the point that one becomes suspicious
      Therefore, your experience is of great importance. Is it really as good as it looks or ?​...
      03-04-2024, 09:53 PM
    • Veyron7887
      Laptop overheating after replacement thermal paste
      by Veyron7887
      Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
      11-24-2024, 05:08 AM
    • chth96
      Is it good to use chemistronic flux off es835b for flux remover?
      by chth96
      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
      11-17-2023, 07:25 AM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • Azurain
      Elitebook 840 G5 Bios Chip Soldering Question
      by Azurain
      I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
      Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
      04-14-2023, 06:58 PM
