Capacitors in schematic question
  • caphair
    • Nov 2011
    • 1249
    Are the first two caps connected differently than the rest in this row or is it merely a space savor for the schematic to draw the rest like that?
    Or are the rest tied in together in parallel? Just looks weird to me
    • 31094
    Re: Capacitors in schematic question
    the first 2 are caps, the others are filters.
    • caphair
      • Nov 2011
      • 1249
      As in filter caps? I'm trying to locate a short on one of the caps on that rail
        • 31094
        it's a ceramic cap with 4 pins - 2 of them are ground.
        are they nec/tokin prodalizers?
        • caphair
          • Nov 2011
          • 1249
          Why 4 pins? Can you explain difference between regular caps? I'm not sure what type they are. Don't think I've run across them before. They're super tiny on an iPhone board
            • 31094
            you can get caps that are like a ceramic block with a signal connection on each end connected together across the cap, and earth connections on the sides.
            they are used for filtering signals usually.
            • caphair
              • Nov 2011
              • 1249
              I see. That GPU line supposed to have at least 1v on it but it's missing tried running a jumper from CPU line which is 1v to cap c0466 but still phone doesn't boot.
              • capwizard
                • Jun 2016
                • 1991
                U0201 POP-FIJI-1GB-DDR-B0 is A 1gb RAM inside CPU. 1v on the cap c0466 which is Data line voltage, u need to use oscilloscope to see the waveform.
                Power Supply IC PM8019 Chip for iPhone 6 which is the one u need to trouble shooting.
                • caphair
                  • Nov 2011
                  • 1249
                  Are you saying I can only see the 1v with an oscilloscope or it should be there visible with a voltmeter?
                  Also schematic says vcc main should be 4.6v but I only measure 4.2v. Wonder if pmu chip partly shorted causing that
                  • capwizard
                    • Jun 2016
                    • 1991
                    In the circuit diagram Power Supply IC PM8019 Chip use 5 sections of circuit diagram to explain the function of this chip.
                    Sorry! about the picture,I cant upload modified PDF file,so I did as you took picture over monitor. .
                    pic1 is all the system diagrams all put together.
                    In the circuit diagram use SYM 1,2,3,4,5 of 5 to show it.
                    in your posted fist picture, show A 1gb RAM inside CPU U0201 on SYM 15 of 15 mean last page. So the U0201 has 15 system diagrams.
                    • capwizard
                      • Jun 2016
                      • 1991
                      low resistance voltmeter will drop the signal and 1v mean peak to peak voltage. so you can't do this ( running a jumper from CPU line).
                      If there has a short, at somewhere in the circuits will drop to 0v.
                      • caphair
                        • Nov 2011
                        • 1249
                        So is it possible the 1v IS there I just can't see it without a scope?
                        It's only voltage that I was missing when checking the output voltages of the PMU. The phone is only drawing 50ma when turned on but a properly working phone draws more around 80ma-1a
                        So pm8019 is different than the bigger PMU chip u1202? I thought that was responsible for power?
                        • capwizard
                          • Jun 2016
                          • 1991
                          I love this Grandma. she can make your iphone 6 came back to life.
                          Grandma? Seriously?.....Start any motherboard by shorting power pin to ground.
                          https://www.youtube.com/watch?v=qqaT_HfbAl4
                          Should you put your phone in rice? Only if you want to buy a new phone
                          https://www.youtube.com/watch?v=plmElKA6qKM
                          • caphair
                            • Nov 2011
                            • 1249
                            Those videos don't address the issue I have unfortunately lol
                            • capwizard
                              • Jun 2016
                              • 1991
                              She is my Adele. No problem, then try this guy.
                              How to use rice to repair water damage on iPhones and Macbooks
                              https://www.youtube.com/watch?v=yPeITOz2_YM
                              • caphair
                                • Nov 2011
                                • 1249
                                Those videos don't help me. Why'd you say to check that broadband power chip?
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  The phone is only drawing 50ma, Also schematic says vcc main should be 4.6v but I only measure 4.2v. Wonder if pmu chip partly shorted causing that...
                                  Water damage is unpredictable. from 4.6v to 4.2v and current from 80ma to 50ma mean partially working, most likely is data or address lines shorted cause some chips is not working, it could happen to anywhere because data and address lines are parallel together. , if pmu chip partly shorted will causing more current reading but not on the data or address lines .
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    So how could I figure out which chips are not working in this case?
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      Its hard.
                                      Yesterday, Ive changed touch ic on iphone6. I bought both of them U4201 and U4202 and try in the air. some people use finger to push down and find the problem. But this one is an easy common problem than yours.
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        Doesn't the iPhone 6 have one power management chip responsible for all other chips voltage input?
                                        • Lef de art
                                          Different capacitors in the sassi and different values in the schematic !
                                          by Lef de art
                                          Hello guys.
                                          Recently i finished my first restoration in a 61 years old tube reel to reel recorder (Geloso G258) .
                                          Thanks God the process ended positively and the recorder works again very good.
                                          In this process i met a big problem by trying to figure what value in capacitors to use.
                                          I say this because all the capacitors excluded the electrolitic had different values from the capacitors in the sassi !!!
                                          Not one or two capacitors. It's about 12 capacitors !!!
                                          For sure i have the correct schematic.
                                          At the end i have used...
                                          11-03-2019, 04:22 PM
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • atunguyd
                                          Acer x163w Monitor PSU schematic
                                          by atunguyd
                                          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                          03-05-2025, 02:08 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
