attempt to clone LED TV Backlight Tester
  • capwizard
    • Jun 2016
    • 1991
    Im attempt to clone ShopJimmy SID GJ2C LED TV Backlight Tester.
    Don't wanna spend money on another electronic waste.
    Can I use PWN IC from AC adapter or use PFC IC which most high-end TV power supply has to archive my goal.
    I don't understand how could Tester can test one to 100 leds , is because the 2mA current feed back limitation,or they used big capacitor slowly charge up the Vstartup.
    The max power is about 300v 200ma, 60w
    Any help would be very appreciated.
    http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
  • capwizard
    • Jun 2016
    • 1991
    Re: attempt to clone LED TV Backlight Tester
    Inside the Tester,Looks like this.
    Similar to this circuit.
    Transition-mode PFC controlle L6562A
    https://cdn.badcaps-static.com/pdfs/...8e89c6f9ca.pdf
      Can we see the straight shot of the bottom side of the board?
      • capwizard
        • Jun 2016
        • 1991
        I did not have this Tester.
        He has it
        cliff_hootarski : Got one and does exactly what it's supposed to do. Can test whole string or each LED individually. Just another tool in the arsenal.
        LED Tester - How to Test LED Backlighting - SID GJ2C LED TV Backlight Tester
        https://www.youtube.com/watch?v=4DS8_utsLPo
        Check at 3:23, the tester shows 293V DC when it touchs one led it drops down to 2.0v then goes up.
        Basically is a 300v 2.5ma current source, if more than 4ma the Tester shuts down and does soft start until it reaches 2.5ma
          • 31294
          seen those type of things on aliexpress / ebay etc.
          they arent expensive
          • capwizard
            • Jun 2016
            • 1991
            Thank you, but I'm try to learn, is the tester using linear or digital to achieve voltage slowly goes up. I saw one microprocessor that is for the 7 segments voltage led display.
            Hop! I could use two resistors to change AC adpter or PFC power to a LED tester.
              • 31294
              no chance, your comparing a voltage regulator to a current regulator.
              the feedback is completely different.
              • capwizard
                • Jun 2016
                • 1991
                L6562A PFC has voltage error amplifier and current error amplifier (comparator). (similar to TL494)
                Transition-mode PFC controller L6562A
                  • 31294
                  there are chips from maxim and linear technologies designed for current-regulated led psu's
                  start with those datasheets
                  • capwizard
                    • Jun 2016
                    • 1991
                    Thank you very much, Maxim and linear technologies do have a lot of PFC to LED applications.
                    When i was young , I was amazed by one AAA battery can light up a fluorescent light tube.
                    After college,I found out, It's only an oscillator. For LED TV Backlight Tester was an oscillator+sophisticated OP amp+MosFET, basically is a 300v 2.5ma electronic oscillator.
                    • gabiz_ro
                      • Mar 2011
                      • 171
                      • Romania
                      Is not clear for me what happens when you apply high reverse voltage on single led testing.
                      For strings seems OK but in case of single led when you apply forward voltage it drops to lower value but in reverse still tester stay on high voltage.
                      I see some led's are protected by a diode or something in reverse
                      (tested on some LG strips,no sign of light on my multimeter set on diode measurement,but in reverse get 0.6-0.7 value,later I light them up on power source,was two series led in same capsule and diode in reverse position)
                      In that case no damage to led but if protective diode what is when you apply 300V on them,on datasheets reverse voltage is low enough.
                      • capwizard
                        • Jun 2016
                        • 1991
                        After burn tons of LEDs. Problem of L6562A PFC has voltage error amplifier and current error amplifier , but the current is not precision. So all the current mode pwm controller ICs are not perfect for this purpose.
                        We will need Precision Current-Limiter.
                        Special thank to BUDM:
                        You will need constant current source (to limit the max current to about 20mA) for testing power supply that can put out >102V (3.4V x 30 White) to test the whole string or you can test each LED by utself.
                        http://www.maximintegrated.com/app-n...ex.mvp/id/3256
                        You have to be real careful testing the LED strip without current limiter or constant current.
                        So have 5 LEDs on the strip and you apply 17.6V directly without any current limitter, and if one of the LED shorted out, then the current flowing through the string will be so high that can damage the good LEDs. I use power supply that I can adjust the current.
                        If you do not have one, you can use LM317 with heat sink as constant current source for driving LED.
                        You can easily do the experiment and measure DCA through your LED string with your 17.6V power supply, then short out one of the LED to see what happen to the current and then look at the spec of the LED for the current handling..
                        LED is not linear device.
                        I do not understand why people keep trying to run the LEDs without any current limiting in place.
                        http://led.linear1.org/why-do-i-need...r-with-an-led/
                        Yes! LM317 is the choice. But! the voltage of LM317HV is about 57v. We will overcome this problem, we will need an output-voltage range of 0V to 300V.
                        Pictures were stolen from here.:
                        https://www.youtube.com/watch?v=vroEf_GtIowe
                        • capwizard
                          • Jun 2016
                          • 1991
                          After 2 days breadboard with LM317, I still have problem with it.
                          The problems of LM317 are not not precision enough to do a TV LED TESTER job.
                          1: Good for fixed high current source (> 10ma) not a good current limiter. Maybe LM344 is batter.
                          2: LED is an active load - semiconductor device and can not consider as direct resistive load . I cant test one led then 10 leds because the LM317 act very unstable.
                          3: To stabilize the current, the input voltage must be at least the LM317 overhead voltage + Vref + combined Vf of all the LEDs and must of course be able to maintain that at the load current.
                          4: The LM317 is not a precision reference device, it will slightly change it's reference and regulation current as it waits rms up.
                          5: The current is decided by the voltage drop across the resistor, is it's value staying the same as it warms up?
                          6: The LM317 with the single series resistor between output and adjust input is actually a fixed current source, not a current limiter.
                          7: Maybe we focusing too much on the LM317. If we need a constant current we could use the LM334 which is a programmable current source for up to 10mA.
                          8: In Fig. 5 we have only a single LED yet the current remains 120mA. The load doesn't change the current from a constant current source in fact I could short out the output and maintain 120mA. Note the LM317 will get hot - and voltage not dropped by the load will be dropped by the pass transistor, LM317 etc. Don't go wild with a large Vcc powering a small voltage load.
                          http://www.bristolwatch.com/ccs/LM317.htm
                          So, we will need new version of LM317: That is LR8
                          High Input Voltag Linear Regulator
                          Commonly used 3-pin linear voltage regulators, for example the LM317, cannot handle input voltages in excess of about 30V. The LR8A from Supertex Inc is a new, adjustable three pin regulator that can accept input voltages up to 450V and can supply an output current of 0.5mA to 10mA. Using this device it is possible to work with rectified 230VAC. The LR8 has a wide input voltage range of +12 V to +450V. Two external resistors (R1 and R2) allow the output voltage to be adjusted from 1.20 V to 440 V provided that the input voltage is at least 10 V greater than the output voltage. The LR8 adjusts the voltage difference between the Vout and ADJ pins to a nominal value of 1.20V.
                          http://www.microchip.com/wwwproducts/en/LR8
                          BTW, Microchip Acquires Supertex, Inc.
                          • cpt.charlie
                            • Sep 2013
                            • 270
                            • Spain
                            After a quick research in google i found the richtek RT7320, maybe with one of these and a boost converter is all you need.
                            • capwizard
                              • Jun 2016
                              • 1991
                              Muchas gracias compa.
                              richtek RT7320. Perfecto,exactamente lo que necesito.
                              I love the built in 2.8ma, 5.5ma, 10ma, 20ma, 40ma current switch. I will order from: http://www.digikey.com/product-detai...0-1-ND/4733241. I will post the result. Thanks aqain.
                              Programmable Regulated Current : 2.8mA to 78.3mA.
                              AC Input Voltage : 90 to 130VRMS or 200 to 240VRMS
                              Cant wait,so Ive ordered from Aliexpress. You make my day.
                              • capwizard
                                • Jun 2016
                                • 1991
                                Ive found one mistake on the Richtek Technology company's product manual.
                                On page 6 Typical Operating Characteristics chart, Output Current vs. OUT Voltage, Output Current marks is wrong. Should I question about how good is their products? I hope not!
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  Boy's & girl's LED tester
                                  Cool Science Experiment - Potato Battery
                                  https://www.youtube.com/watch?v=EFuF2Tsg9HY
                                  We will need 10 lb to test LED strip and 100 lb to test LED screen
                                    Using RT7320 for testing LEDs (depends on how many LEDs there in the string) you will still need variable Voltage power supply otherwise it will exceed the power dissipation of the IC.
                                    The IC is just a higher Voltage low side (current sink) with built-in resistors for selectable constant current,
                                    Basic OPAMP+ MOSFET constant current power supply:
                                    https://cdn.badcaps-static.com/pdfs/...25bd060cc5.pdf
                                    http://www.daycounter.com/Circuits/C...nt-Servo.phtml
                                    https://cdn.badcaps-static.com/pdfs/...43730e4b17.pdf
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      Thanks for your friendly reminder: you will still need variable Voltage power supply otherwise it will exceed the power dissipation of the IC.
                                      Because, It is a LED tester for average 5 sec usage in small mount of leds maybe OK, for larger screen definitely will need big heatsink.
                                      1996 presidential candidate Ross Perot said: I didn't care whether we make potato chips or computer chips. Well, anybody that thinks about it cares a great deal. Number one, you make more making computer chips than you do potato chips.
                                      I also member he said: making computer chips is easy as making potato chips, all you need is money. Well, so damn right, for people as rich as him.
                                      OPAMP+ MOSFET +constant current control circuit ....Now, all that can be put inside one IC , in no time. We will facing more variety ICs, like PFC power controller. For example, Samsung in different year , different model, different size of tv , use all different kind of PFC controller. make this simpler word more complicated.
                                      A custom analog ASIC (application specific integrated circuit) can be developed in a very short time, push the boundaries in analog design lowering cost, or reducing power consumption, or increasing integration levels or circuit performance. We will see more and more this kinds of potato chips just for LED lighting application.
                                        "OPAMP+ MOSFET +constant current control circuit ....Now, all that can be put inside one IC , in no time" That are what inside the RT7320 if you look at those links.
                                        'Because, It is a LED tester for average 5 sec usage in small mount of leds maybe OK, for larger screen definitely need big heatsink." You will need bigger heatsink when testing one or two LEDs in series if the Voltage is not adjusted down ward because you will have more Vdrops on the MOSFET, it is constant current circuit. The more LEDs in series the less Vdrops on the MOSFET so less heat.
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • canadaboy25
                                          LG Flatron 24EN33TA No Backlight When Cold
                                          by canadaboy25
                                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                          03-07-2023, 12:23 AM
                                        • gabrielA7
                                          Macbook pro A1706 / Backlight flex cable compatibility
                                          by gabrielA7
                                          Hey guys!!
                                          I’ve got a question here!
                                          I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
                                          Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
                                          Here’s what the bot told me:
                                          I said to him: “I’m going to install the 821-01229-A.”
                                          ChatGPT replied:
                                          Understood — but before you solder or install the 821-01229-A,
                                          11-11-2025, 03:26 PM
