Helium-neon lasers
  • japlytic
    • Oct 2005
    • 2086
    Helium-neon lasers
    Some of you may know that the early LaserDisc players and laser printers used helium-neon laser tubes, which have been replaced by strong semiconductor lasers which are more compact and efficient.
    With this in mind, I became curious about whether early CD players, CD-ROM readers and even CD recorders, along with other optical recording readers/writers (other than LaserDisc players) ever used helium-neon lasers - did any of these devices use such lasers?
    • 31020
    Re: Helium-neon lasers
    unlikely - have you seen the size of the tube?
    i'v got a couple.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i dont recall cd devices using them.
      i still have some including some compact ones with 12v supplies.
      these would be too big to fit a cd drive.
      • redwire
        • 3910
        I have a 1mW HeNe laser tube, it is about 10" long and 1" O.D from a grocery scanner bar-code applications 1.4kV at 4.5mA power. Spectra-Physics 088.
        You'd need precision movable mirrors to move the beam across a CD/LD which is not cheap at all. And they are just plain huge.
        Amazing to see the same brightness but fatter beam in a $0.99 laser pointer.
        • Dannyx
          Hilti PD30 Laser Range meter Error 276
          by Dannyx
          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
          07-30-2023, 05:05 AM
        • dansity
          Power DeWalt 12V laser measure from power supply
          by dansity
          i got a Dewalt laser measure which uses the 12V batteries to operate. The laser measure is faulty and I want to attempt a repair, never fixed such thing before. You might see a different topic if I fail with the repair
          However I do not have dewalt batteries nor want to buy one for 140EUR as the laser tool might have some chance that it is very hard to repair or unrepairable.
          I want to power it from my PSU.
          The tool has 3 input pins, on the battery it is marked with B-, B+ and ID/TH.
          i want to know what is the third pin exactly and what do I need...
          10-29-2023, 03:04 AM
          I would like an explanation of how a laser can measure a product on a conveyor belt
          by sam_sam_sam
          I saw this on
          “How do they do it “
          The laser was measuring the diameter and the height of the product and the weight of the product and it was a straight line laser light across the the conveyor belt ( this is all that was shown in the video clip of the laser that was used )
          What type of product is this that can do this
          I want to thank anyone that knows what of laser this is
          04-24-2022, 07:55 AM
        • SONY_E-WASTER
          KONICA MINLTA C250P (laser) all prints have unwanted vertical CMYK lines
          by SONY_E-WASTER
          Hello I'm a rookie tinkerer hopping to find some knowledge about these big color laser printers and copiers.
          The specific model I would like to fix.
          KONICA MINOLTA C250P this is the printer only version of the full office photo copier. I have a one of the full office copier version for part too (that one gives an error for the yellow laser).
          https://photos.app.goo.gl/cwVu2KYB6Yva5Ais6
          I'm adding a link above to a picture of print out form the C250P with visible vertical lines of CYAN YELLOW and MAGENTA mostly on the right side of the 11x17 print....
          02-03-2022, 08:02 PM
          Modifying a Engraving Laser Module with out a TTL Module
          by sam_sam_sam
          I bought this laser module a few years ago and did not do anything with because I did not have a TTL module so it sat in project box to do something with at a later date
          Well the later date has happened now
          What I did to this module is disconnected the cooling fan and going to use with a fan temperature speed controller ( out of a surplus computer switching power supply )
          Well now I have found a 15 watt TTL module that I just bought from AliExpress which I should have in a few weeks
          Some time later when I have learned to use a laser engraver...
          07-25-2020, 02:26 PM
