Motherboard Power-On Circuit
  • DaleCarr
    • Sep 2015
    • 14
    I've recently run into a few motherboards that won't power on when jumping the power button pins. Going back to the root of all evil I first checked my PSU for the +5v Standby then checked it all the way to the pin. All Good. Even checked other standby places on MB and got the +5v. PSU will kick if jumping the Green wire on the 24 pin connector but will immediately shut off when pulled. When it is running I'm not getting normal post nor video. I have repaired alot of SB950 chipsets for video problems in the past. so my question is. Does the Power_On circuit also run through the South Bridge and it being bad create a fault in the Power_On Circuit.
    I sem to be running into more and more of these boards with this issue and would like to figure this out. This particular board is the Asus M5A97.
    Any ideas on this would be greatly appreciated.
    Dale
  • Geeker007
    9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
    by Geeker007
    Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
    I am new to electronics repair, so my queries could be naive but I am ready to learn.
    So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
    01-28-2025, 03:31 PM
  • glovecaps
    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
    by glovecaps
    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
    11-25-2024, 04:23 PM
  • ronaldopdias
    Acer Aspire 3 A314. Not Charging.
    by ronaldopdias
    Laptop Model: Acer Aspire 3 A314
    Motherboard Model: DA0Z8EMB8C0 - Model: Z8E
    Charging IC: BQ24780 which I have repalced.
    Issue Description:
    I'm experiencing an issue with the charging system on this laptop. The BQ24780 charging IC is not working as expected. The main problems are:
    1. ACDET is missing (0V):, Reading 0V on the ACDET pin.
    2. ACOK is not present (0V): Is missing as well.
    3. No SMBus signals (SDA and SCL are missing): The SDA and SCL signals for SMBus communication are not present. There is no clock (SCL) or data (SDA) activity on these lines.
    What I Have...
    12-19-2024, 04:15 AM
  • Docus
    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
    by Docus
    Hi everyone 😀,
    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
    1. I already own the exact same model, but its plastic chassis is badly damaged.
    06-10-2025, 04:24 PM
  • AstutePauciloquent
    Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
    by AstutePauciloquent
    Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
    I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
    11-23-2023, 11:02 PM
