need equivalent k10a60d
  • HABIBOU11
    • Jul 2015
    • 50
    • ALGERIA
    Hi
    need equivalent of k10a60d
    can i use k3797 ?
    thanks
    Хвала Аллаху, Господу миров
  • tw2005
    • Oct 2011
    • 6458
    Re: need equivalent k10a60d
    Originally posted by HABIBOU11
    Hi
    can i use k3797 ?
    thanks
    comes up as one in this cross reference site.
    http://alltransistors.com/mosfet/crs...&caps=TO220SIS
    • HABIBOU11
      • Jul 2015
      • 50
      • ALGERIA
      thanks
      • connorcc2005
        Thermistor specs and cross reference
        by connorcc2005
        I'm getting some conflicting information and thought I'd toss it out to all of you for input.
        What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
        The physical diameter of the piece is 5.1mm measured with a caliper.
        Other than what you see in the pic, there is no other writing on the part.
        My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
        06-16-2022, 04:16 PM
      • karlox
        IC UP9002p "equivalent"
        by karlox
        Good evening, colleagues.
        Does anyone know an equivalent or a compatible replacement for the uP9002P IC (power controller)? Alternatively, does it come under any other marking or code on different boards?
        Any insight or cross-reference would be greatly appreciated. Thank you in advance!
        09-01-2025, 08:43 PM
      • raregtp
        Voltage regulator cross-reference
        by raregtp
        Hey all....hoping someone can help me with this. I have a couple voltage regulators I'm trying to cross but not having much luck.
        The first is:
        A1
        AS1117L-18
        B0640 25
        The second is:
        A1
        AS1117L-33
        B0640 28
        I know the AS stands for Alpha Semiconductor, and I think I've found a datasheet for the AS1117L-33, just can't find anything for the -18. Ultimately I'm looking to cross these over to parts that I can get now, as all I'm finding similar are AZ1117 regulators.
        If anyone can assist...
        03-15-2020, 11:12 PM
      • jasko_jacker
        cross reference tps51285a
        by jasko_jacker
        I try to substitute the RT6575B with TPS51285A,
        it seems to work but it is slightly warmer, the board does not start due to other problems so but not sure if replacement is possible...
        12-07-2021, 01:49 PM
      • speaktorob
        Reference Nvidia GTX 980 ti - looking for a new shroud
        by speaktorob
        So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
        Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
        03-22-2024, 03:00 AM
