Rusted fans
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Rusted fans
    So, I'm recovering these PCs and two of them had rust in one of the fans. First, one wasn't so bad, but the second, well I'll let you see for yourself (pictures in the attachments). Has anyone encountered something like this? I have to say that this is a first one for me. I did fix the fan, but unfortunately I forgot to take pictures... I might open it up tomorrow, if I'm not too lazy.
    P.S. The fan is from a delta PSU, though I can't remember the model. Oh, and yes, it did have bad caps.
    Keyboard not detected, press F1 to continue...
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Rusted fans
    Extreme humidity does that. I have seen it once or twice.
      • 31066
      Re: Rusted fans
      was it near the coast?
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        Re: Rusted fans
        Does Norway have anything but coast?
        sigpicThe Sky Is Falling
          • 31066
          Re: Rusted fans
          yes, it has sweden on the other side
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Re: Rusted fans
            Originally posted by reaper57
            So, I'm recovering these PCs and two of them had rust in one of the fans. <snip> Has anyone encountered something like this?
            Yes, see here:
            https://www.badcaps.net/forum/showthread.php?t=49578
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              Re: Rusted fans
              Two men in a bathtub.
              • reaper57
                • Sep 2014
                • 216
                • Norway
                Re: Rusted fans
                I do live in a city near the coast, but the air isn't very moist. However, I don't know where the computer was used. All I know is that it belonged to some company or institution. At first I though that maybe it was on an oil rig or a ship, but surprisingly enough the hard drives weren't taken out.
                Anyway, here are the pictures I promised, sorry for the delay.
                The first two pictures were while the fan was dry. The brown color in second two pictures is because of the oil (and probably the light too).
                • emil_t
                  RTX3090 working fine but fans not spinning
                  by emil_t
                  Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                  04-12-2024, 06:54 AM
                • JayPoorJay
                  Hot Water Rad - A Few ECU Fans and a Timer Switch
                  by JayPoorJay
                  Good Afternoon, Good People.
                  I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                  I REALLY would appreciate y'alls help.
                  This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                  10-29-2024, 12:54 PM
                • bohaboha
                  Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                  by bohaboha
                  Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                  anyhow i couldn't t read anything else
                  the backlight is on strong and the screen does not get dark or very dark but no pictures
                  the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                  01-02-2025, 08:04 PM
                • valvashon
                  LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                  by valvashon
                  The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                  Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                  11-24-2024, 12:08 PM
                • sda sad
                  my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
                  by sda sad
                  Hope this is the right place, someone can help me.
                  My laptop started having a really strange problem....
                  When I turn it on the fans start working at a crazy rate and with random breaks...
                  They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
                  And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
                  The model of the computer:
                  Xiaomi Notebook Pro X 15 OLED (A30)
                  04-23-2024, 09:55 AM
