pc power and cooling.ball bearing my ass!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    found this failed fan in a starrett cmm.
    i tend to autopsy things and got a surprise when i peeled the label on this fan!
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: pc power and cooling.ball bearing my ass!
    ROFL! Good find.
    A man convinced against his will is of the same opinion still.
    • bgavin
      • Jan 2007
      • 1355
      Open up a PC Power & Cooling PSU... find the Fuhkyoo caps inside.
      I emailed them about using premium caps, and got a snotty answer back.
      To which I replied, "Fuhjyyu". No PCP&C supplies for me or my clients.
      I am not at all surprised to find false labels on hardware anymore.
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        Really! This calls for pics. Last I heard they use Teapo.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Looks like a Pentium I cooler or 486 cooler. LOL.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Wizard
            • Mar 2008
            • 2296
            Actually take the snap ring off and take the fan apart rest of way. You will find exactly one ball bearing and sleeve bearing that you are seeing.
            Cheers, Wizard
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Yep, that's the truth. If the label said "dual ball bearing", you'd have something to complain about... but... no, it has exactly what it advertises... "ball bearing". No "s" at the end.
              Ludicrous gibs!
              • Logistics
                • Apr 2007
                • 721
                I've never had a sleeve-bearing fan like this completely fail. Every single one that I have had that locked up, I could dismantle, clean, lightly lube with a little transmission fluid and BAM it was a screaming new fan, again.
                Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                • 999999999
                  • Sep 2006
                  • 774
                  True, lubing a fan may revive it though sometimes when it's a one ball, one sleeve bearing the debris from the sleeve bearing, or the lube, may get into the ball bearing making it short lived or noisy. I'd rather an all-sleeve or all-ball bearing instead of a hybrid.
                  • Wizard
                    • Mar 2008
                    • 2296
                    Certainly not, Every sleeve & hybrid ball/sleeve I had fail. Either seize up or get loose and noisy. Had lost caps to a seized up fan. Had to rebuild PSU with good fan and capacitors replaced. I wasn't aware the fan was not spinning because I had it spinning slow.
                    Experience tells me don't bother with these fans and I DID take apart and clean out solidified old oil completely. Fan didn't last long or too loose. The oilite bearings is porous and once oil gums up, sleeve can't retain oil at all and disappears quickly and at the point fan is worn already. So every PSU and any stuff that use fans get premium dual-ball fans. Retail intel fan heatsinks is *decent* for what is intended to be used and really have dual ball fans.
                    Cheers, Wizard
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
