VGA LCD controllers
  • tvduude
    • Jul 2012
    • 67
    VGA LCD controllers
    question about the LCD controllers that connect a panel to your VGA port.
    theres some "universal" controllers on ebay and other places that are standalone and bypass all your existing boards except i guess for the tcon.
    i got a free 37" 2006 model Philips TV that was wacked by lightening.
    took out the guys modem and electric stove also.
    rather than try to fix itwhich i'm not very good at. thought i would try one of these controllers.
    However i cannot find one that lists the exact panel and a couple emails to sellers has not been succesful. I know there is a programmer for sale for those
    but have yet to determine where the firmware library store for these are located.
    Is there a popular forum that has alot of discussion on these devices?
    the model of the Tv is 37pf963 and the panel is LK370t3lz Sharp in case anyone is better at finding the controller or firmware than i.
    there may be another digit on the end of that panel number but i'm too lazy to go look right now.
    any help is much apreeshd.
    thx.
    oh also theres a youtube on that Tv in repair if you search that model.
    i'm thinking maybe try to satisfy power requirements to test the tuner board and inverters externally with other power sources if i can find the power requirements and pinouts.
  • SurrealMustard
    • Jan 2015
    • 486
    • The United States of America
    Magnavox question
    I'm actually thinking about doing the same thing. I've got this circa-2007-ish 42" Magnavox LCD television that I can't seem to be able to sell. I was considering using it as a monitor, but the mainboard sucks and won't take native resolution through the HDMi port. I saw a video on YouTube where someone actually got it working with the existing power supply and a universal LCD controller; the problem is that he didn't go into enough detail for me to feel confident in doing it myself.
    Anybody done this before with a larger panel or have any hints?
    • japlytic
      • Oct 2005
      • 2086
      Re: VGA LCD controllers
      When I buy VGA-LCD controllers (for LCD conversions of equipment), I always buy the LCD panel to suit to be sure it is compatible (if I don't have the compatible panel!).
      You would need to know the signalling levels and data format for the LCD panel as well, along with the controller.
      • SurrealMustard
        • Jan 2015
        • 486
        information
        Well, I'm not going to buy another panel, I'd be using the one I have already. The question is if these LG panels are compatible with the universal controllers (which I believe they are to some degree because of that video in which it is talked about briefly).
        I don't remember it off-hand, but I think that is all in the panel's informational page on PanelLook. I'm not an LCD panel expert though, so I don't know what information is relevant to making sure that it is compatible with the universal controller.
        • tvduude
          • Jul 2012
          • 67
          i bought the $10 jumper style controller.
          my research says its not safe to try it until the LVDS cable pinouts are verified.
          have no idea how to do that.
          the power relays click on and off unless i unplug the bottom right connector of the
          audio board. it connects to the third connector from top left of the tuner board.
          if i unplug that cable the backlight immediatley comes on with no input or buttonpress with seems a full glow around the edges. no button or controls seem to work at all.
          any ideas for me please chime in.
          Philips model 37pf963
          https://www.shopjimmy.com/philips/37pf9631d/37
          www.datasheetspdf.com/PDF/LK370T3LZ63/907827/1
          http://www.panelook.com/LK370T3LZ63_...view_9293.html
          EW Powerful Universal VGA LCD Controller Board for easy DIY LVDS panel 10inch to 42inch up to 1920x1200 optional by jumper
          Model: MT561-MD V2.1
          • tvduude
            • Jul 2012
            • 67
            was also thinking the surviving backlight is enough to start but to get dimmer control etc would probably want to find a single wire that cuts it off and run it thru a mosfet or something? attached to /( pwm'd by?) the inverter cable on the MT561?
            • tvduude
              • Jul 2012
              • 67
              https://www.shopjimmy.com/philips-31...pf9631d-37.htm
              • howardc64
                LG 49UJ6500 LCD panel lighter band that goes away
                by howardc64
                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                02-19-2023, 12:13 AM
              • triplefour
                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                by triplefour
                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                tcon is built into mainboard.
                Only one cable goes to panel boards.
                there is a cable from one panel board to the other that links them.
                cost cutting measure that results in us having harder time to diagnose.
                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                07-28-2022, 07:59 PM
              • Storyteller12
                QN55Q60R Service Menu Panel Help
                by Storyteller12
                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                01-13-2024, 01:57 PM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
              • KYBOSH
                Samsung UN50TU8000 - Dead Panel Forensic Questions
                by KYBOSH
                I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                Later I checked for shorts on the panel PCB boards but could not find anything.
                When I took a look with the FLIR i noticed the 2 resistors...
                08-10-2024, 08:39 AM
