Test your alligator clips
  • mockingbird
    • Dec 2008
    • 5484
    So I've been using alligator clips to put a 100Ohm reistor in parallel with a battery voltage measurement with my DMM, and I thought I'd check the continuity on the alligator clips.
    Almost all of mine are no good. One of them sort of works, but then fluctuates once you move its wire around. They're all probably oxidized to bits on the inside.
    I inherited these from a fellow's wife many years ago, so I never bothered at the time, but I'm glad I did now.
    master hoarder
    • May 2008
    • 12175
    Re: Test your alligator clips
    If the alligator clips are crimped to the wires, then it is possible that the wires could have oxidized and are causing a bad connection (especially if they are non-copper wires). Or it could be that the wires are just too old and have gone O/C somewhere.
    I bought a bag of small 18 AWG 300V alligator clips from Harbor Freight Tools, and they have been great so far. I think I've had them for over 3 years now. They see lots of use - almost daily. I'm not super gentle with them either. However, they do appear a bit skinny - more like 20 AWG. So I'd take that 18 AWG rating with a grain of salt. Though I will mention that they have sustained currents of 5 Amps without getting even slightly warm. So they aren't awfully terrible either.
      I remember the good old days when those jumper wires with alligator clips on both ends were made in the USA which the wires are soldered to the clips and the clips have nice strong grip, these day the Chinese made one are all crimped type with very poor crimping. I rework them by soldering the wires to the clips.
      • rievax_60
        • May 2012
        • 897
        • australia
        I always find it necessary to solder in better wire. A real problem I have found lately is that the plastic cover boot goes hard making it more difficult to squeeze the clip open.
        I bought some recently on eBay, it is too soon to know if they have the same problem. I have found that the inside of the boot is too slippery. Washing them in turps fixes that.
        • mockingbird
          • Dec 2008
          • 5484
          Thansk for the input gentlemen.
          Surely enough, I slipped back the shrouds, and the two alligator clips that did work have good professional crimps on the copper (It's not soldered), and they have "Made In Korea" etched into the metal.
          All of the other ones only have two teeth at the end which press on the wire, and then they have the copper just shoved behind. It's not a crimp at all. No wonder why none of them work.
          There's a hole where the twisted copper strands can go through and theoretically be soldered on the Chinese ones, but that hole is on the part of the clip that you squeeze when you want it to open. So I can see why the Korean ones didn't use this method, because then there would only be a very thin piece of plastic between your finger and the metal. I don't think these Chinese ones are worth the risk.
          That's something to add to the shopping list.
            Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
            When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
            This switching power supply was really fun to recap the quality of the board was very good...
            02-25-2024, 08:55 PM
          • chth96
            How Can I test PWM DM0365R?
            by chth96
            Hello
            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
            06-18-2025, 04:14 PM
          • khelane
            test active pfc power with lamp test
            by khelane
            Hello
            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
            Is there a way...
            06-03-2025, 01:00 AM
          • chronic519
            Mats / mods: detected and repaired GPU fault. Cant seem to test after!
            by chronic519
            Hello.
            GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
            Found issue with a RAM block
            Replaced, green lines gone.
            Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
            Used a good card to test and same results low errors 32+.
            I am just search for some form of command to do a full test on the GPU.
            I just ran the mats command with my good GPU and passed after roughly 40 min.
            The repaired one, ran...
            05-20-2025, 07:56 PM
          • langbaobao
            DIY 3D-Printer WSON8 Pogo Pin Adapter
            by langbaobao
            Hi.
            I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
            I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
            01-08-2024, 05:58 PM
