A simple circuit to test PWM fans
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I'm looking to build a simple circuit that I can use to test fans that use Pulse Width Modulation. I currently have a three wired fan and if I provide 12V to it, it just spins for a second and then stops. I'm pretty certain the fan is good. I'd ultimately like to have something where I can easily test 3 and 4 wired fans. Does anyone have any schematics for something that would allow me to do this? I just want to be able to use something like a pot to change the speed of the fan. I have a variable power supply now so I can just set it to whatever voltage the fan takes and hook it to the wire.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • 31159
    Re: A simple circuit to test PWM fans
    you can probably find circuits based on a 555 timer chip.
    or use a microcontroller.
    • Spork Schivago
      • Mar 2012
      • 4734
      I like the 555 timer idea. I've never used a microcontroller before. I'm not against using one, I just have no idea how they work and I know nothing about them except that they're in a lot of different things. I saw some simple circuits using a 555 but it said stuff like it can only do 10% duty cycle and 90%.
        • 31159
        isnt 10-90% enough for testing?
        • Spork Schivago
          • Mar 2012
          • 4734
          My understanding wasn't 10% - 90%. It was 10% or 90%. Maybe I misunderstood it. I will try to find the schematics again for it. It was really poorly written. The person was 15 years old they said and the schematics didn't match the breadboard. For example, the breadboard had a cap but the schematics didn't. Some people some how got it work just fine, other people said it burned out a 555 timer. I was hoping for something better. If it can do 10% through 90%, that's more than fine. I mean, I guess 10% or 90% would be fine for testing too. I just thought it'd be nice to be able to adjust the speed to whatever via a pot or something.
            http://www.dprg.org/tutorials/2005-11a/
            But the fan you are trying to drive has the PWM control pin or any spec of the fan you are trying tot drive?
            • Spork Schivago
              • Mar 2012
              • 4734
              Right now, the fan I am trying to drive is a 3-wire Nidec G10C12MS1AH-56J14 12VDC 1.38A fan, however, I'd like to make something that I could use to test various 3 and possibly even 4-wire fans in the feature, just not this fan.
                NIDEC simple PWM control.
                http://www.nidec.net/apps.htm
                http://www.overclockers.com/pwm-fan-controller/
                  • Jul 2011
                  • 6058
                  Originally posted by budm
                  Thank you for posting that link I have need a pwm controller using a 556 timer IC chip
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    Are these schematics good for my fan? The fan I'm currently interested in testing requires 12V it says...these schematics make it look like it only provides 5V.
                      The PWM Controll pin requires 5V PWM signal, the Power Voltage for the fan to spin is 12Vdc, do not get confused between the Control signal (low current) circuit and the Power Voltage for the Fan drive circuit (high current).
                      You need to look up the fan spec to find out what the electrical requirements are.
                        Note 4 wire fans use a fast PWM signal @ 25kHz. Slow PWM fans, ones controlled by switching the 12V supply, work at a much lower frequency, usually less than 100Hz.
                        The reason for moving to the high PWM frequency is the motor driver on the fan can control the current modulation more precisely for a specific speed. Whereas low frequency modulation usually results in the fan accelerating and slowing down rapidly at the PWM frequency, causing increased noise.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Thanks guys! I would of built this buy now but I needed to earn some money so I've been busy working on other stuff. I'm all caught up for a bit now so I think maybe tomorrow or the next I'll start working on building this and learning more about creating my own hardware. Just need to take a little break first.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            I know it's been awhile since I last visited this topic but I had a question. The schematics Budm posted seem to use the fast PWM signal you talked about here Tom66, roughly 25KHz. Would I still be able to use this with the slower PWM fans? There wouldn't be any trouble, right? It'd just run at full speed, right?
                            • Nevillet
                              Simple PIR sensor circuit to drive a small motor
                              by Nevillet
                              Hi All,
                              I'd like some help designing a simple circuit for driving a small DC motor.
                              The PIR module is a HC-SR501 which runs on 6V supply and outputs 2.4V when triggered. (Datasheet attached)
                              I'm not totally sure which motor I need yet but lets assume it'll be 12V and draw a maximum of 100mA.
                              Can somebody design me a simple circuit for me using something like a 2N3904?
                              I'm happy to include a relay if that makes sense.
                              Many thanks.
                              https://www.badcaps.net/forum/attachment.php?attachmentid=3...
                              07-09-2023, 10:48 AM
                            • emil_t
                              RTX3090 working fine but fans not spinning
                              by emil_t
                              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                              04-12-2024, 06:54 AM
                            • Crrose
                              How to test circuit board battery connection.RS-4i sequential stimulator
                              by Crrose
                              Not sure where to post this but I have an RS-4i sequential stimulator that runs off rechargeable batteries and also has a VL2330 coin cell battery that retains the memory. If that battery doesn't hold charge or connection is bad then the unit will power on and say to recharge. Once it is charged it indicates it is charged but when you turn unit on it powers off saying to charge batteries. I replaced that coin cell battery and now it won't even indicate batteries need to be charged. I have tested the battery pack and it is fully charged at 6V but the coin cell only shows 2.97V which is a brand...
                              03-21-2023, 03:55 PM
                            • harp
                              Simple current variable circuit
                              by harp
                              At electronic point of view, what circuit is best in performance to control shutdown pin of adjustable voltage regulator, and why?...
                              09-14-2024, 05:54 PM
                            • bendeg
                              Test circuit for curiosity : 2 x NE555 (astable + PWM) + n-mosfet + var 10k + pc fan
                              by bendeg
                              Hi reader,
                              I'm trying to control a pc fan speed by giving PWM to the gate of a n-mosfet.
                              1) generation of a clock with a 555 timer (~ 1,5 kHz, as seen in the datasheet, fig.12) (Vcc = 6V).
                              Output to TRIG of second timer (pin 2) + red led
                              2) generation of a PWM with a second 555 timer (as seen in the datasheet, fig.18), CONT (pin 5) modulated by a variable 10k resistor (Vcc)
                              3) Using output of second timer to "pulse" n-mosfet gate (MDP13N50) + yellow led
                              4) pc fan (12V, 0.18A) in series in drain-source of...
                              05-01-2023, 07:59 AM
