Help with some old electric fencers
    • 31199
    Re: Help with some old electric fencers
    you can probably damage it by doing a dead short.
    why not compare the coil resistance between the 2 units.
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      Would I measure the coil on the primary or secondary side?
      canadaboy25
      -Sometimes the light at the end of a tunnel is an on-coming train
        • 31199
        both, both are seperate coils.
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          The primary reads 27 ohms and the secondary that connects to the output reads 12k ohms.
          canadaboy25
            • 31199
            on both?
            because if they match they are probably fine.
            btw 12000/27= a ratio of 444.4
            not allowing for losses - 120v x 444=53kv !!!
            this is wrong of course, it assumes the 2 windings use the same thickness of wire resulting in the same resistance per foot/meter.
            but you get the idea!!
            • canadaboy25
              What is normal?
              • May 2013
              • 509
              Yeah they are a few ohms apart but close.
              So the only thing that could be a problem is the caps?
              canadaboy25
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                #27
                yep, fix those cans and recap! also check for any out of tolerance resistors.
                Follow the white rabbit.
                  • 31199
                  what are the caps? we need to be sure they can handle some pulse current.
                  • canadaboy25
                    What is normal?
                    • May 2013
                    • 509
                    On the older unit both caps are 0.25uf 600v and on the newer unit one of the caps are 0.25uf 600v and the other cap is 0.1uf 600v.
                    canadaboy25
                      • 31199
                      hmm.
                      ac power,
                      but the old caps are polarised and marked DC.
                      • canadaboy25
                        What is normal?
                        • May 2013
                        • 509
                        Well the negative leads do go to ground....
                        canadaboy25
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          #32
                          Originally posted by stj
                          hmm.
                          ac power,
                          not polarised, black mark = outer foil. I've worked on shitetons of tube radios with caps marked like that. (damn you Philco!)
                            Originally posted by goontron
                            not polarised, black mark = outer foil. I've worked on shitetons of tube radios with caps marked like that. (damn you philco!)
                            +1
                              • 31199
                              black band is labelled "ground"
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                #35
                                oh, wow. im blind!
                                • canadaboy25
                                  What is normal?
                                  • May 2013
                                  • 509
                                  Haha yeah I was just goint to say that.
                                  canadaboy25
                                  • canadaboy25
                                    What is normal?
                                    • May 2013
                                    • 509
                                    Would these caps be suitable replacements?
                                    http://www.ebay.ca/itm/0-25-uF-600-V...item3f336c8942
                                    canadaboy25
                                      • 31199
                                      1973 ???
                                      get real - go buy some nice new polyester or polypropylene 600v caps.
                                      those are for retro-radio nuts imo.
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        #39
                                        1973 ???
                                        hell, im a radio nut and i use modern polys! listen to stj on this one. besides, when those oil filed ones go
                                        • kaboom
                                          "Oh, Grouchy!"
                                          • Jan 2011
                                          • 2507
                                          1973 ???
                                          those are for the retro-radio version of the audiophools.
                                          fify
                                          Calling someone who uses that junk a "radio fan" is an insult to those who know otherwise.
                                          Yes, that's right- the old paper and "bumble-bomb" caps frequently get resold and otherwise passed around to those who think they'll "make their audio or DX better."
                                          Alright, what does a redplating power tube sound like, and is it really "better?"
                                          Those old caps were/are garbage, and belong in the garbage.
                                          "pokemon go... to hell!"
                                          EOL it...
                                          All style and no substance.
                                          guilty,guilty,guilty,guilty!
                                          guilty of being cheap-made!
