JRC GPS antenna model: JLR-4340
  • Jackching
    • May 2017
    • 159
    Im just trying to clarify how to go about installing a new 6 pin gps connector to this JLR-4340 antenna. It is being used with a Hondex HDX-121-BB plotter. It was previously working with this wiring diagram:
    1-Black
    2-White and blue
    3-Green
    4-empty
    5-Yellow
    6-Red
    Pins 1 and 2 were also jumped
    Anyhow, A.I is telling me a totally different wiring diagram to use this antenna with the hondex plotter:
    1-Red
    2-Black
    3-Green
    4-White and blue
    5-Yellow
    6-empty
    Here is the diagram for the antenna: https://www.manualslib.com/manual/38...?page=3#manual
    Here is the pinout for the Hondex plotter (I think it's the #4 chart): https://www.easymanua.ls/hondex/hdx-121-bb/manual?p=114
    We know the first method I posted works but wondering if there is an alternative to jumping pins 1 and 2 and why it was done this way. It was being used in the native GPS port and not the NMEA ports. Im reading that when it is wired like the first diagram in the post that it was meant for an NMEA port but it was working fine in the GPS port.
    • 32065
    hondex:
    Connector for External Input/Output
    1. GND
    2. Data Input-
    3. Data Input+
    4. N/A
    5. Data Output
    6. DC10.5V 200mA Output
    antenna:
    1 DC 12v input
    2 GND
    3 0v (data)
    4 data out
    5 set data input ??
    6 DGPS input
    interesting, the antenna can output 2 different formats based on how pin5 is connected.
    the terminal i dont know about that +/- input - is it differential?
    • Jackching
      • May 2017
      • 159
      Ya I dunno. I just rewired it the way it was but have no way to test it now because the electronics are out of the boat.
      • Boardview and Schematic Bot
        Huawei P9 Plus Schematics & Boardview
        Huawei P9 Plus WCDMALTE 8 12 13 20 26 28 29 (MMMB) Front Modular Circuit block diagram.pdf
        Huawei P9 Plus WIFI Circuit block diagram.pdf
        Huawei P9 Plus CPU vcc U1101.U1301Circuit block diagram.pdf
        Huawei P9 Plus frame Circuit block diagram.pdf
        Huawei P9 Plus RF Front End Switch Main ANT Circuit block diagram.pdf
        Huawei P9 Plus U3902 LTE Diversity Circuit block diagram.pdf
        Huawei P9 Plus CDMA RFIC Circuit block diagram.pdf
        Huawei P9 Plus power supply U1001Circuit block diagram.pdf
        Huawei P9 Plus...
        10-20-2026, 02:50 PM
      • gabri2211
        I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
        by gabri2211
        hello everyone, I'm looking for the wiring diagram of this led monitor.
        the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
        I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
        I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
        thanks to those who will answer
        12-10-2024, 04:37 PM
      • cicciopap
        Lenovo thinkBook 14 g3 ACL wiring diagram, boardview
        by cicciopap
        Hi everyone, I need a wiring diagram and boardview for a Lenovo thinkBook 14 g3 ACL. Main board GLV3A LA-K061P Rev: 4.0 2021-01-11. Could anyone help me? Thanks in advance....
        05-12-2026, 05:32 AM
      • Ede2001
        I am looking for a wiring diagram or boardview EVGA GTX 780 Ti SC w/ ACX Cooler
        by Ede2001
        I am looking for a boardview file or schematic for the EVGA GTX 780 Ti SC w/ ACX Cooler video card.
        08-26-2025, 03:14 AM
      • Hondaman
        Single-channel antenna?
        by Hondaman
        Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
        I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
        Years ago I made a "T"...
        11-18-2024, 01:14 AM
