Please ID this small chip
This topic has been answered.
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • mferna14
    ASUS TP412F 3.3V Regulator chip gets very hot
    by mferna14
    Hi all., I am working an ASUS TP412F​., motherboard Model TP412FAC R: 2.0. The problem I am facing is the 3.3 buck converter (L8=7J RT6256BGQUF) gets very hot when 19v is applied through DC-in jack. I don't think Schematics or Boardview is availble for this model. The chip get so hot that I can't even take the voltages of the pins. I replaced the chip but the problem is still there, new chip even gets very hot. The input on pin 5, 19v is present. So I removed the Output coil & the chip & checked the voltages on the chip pads which are as below: Please view if any volts seem to be abnormal....
    07-09-2024, 11:57 AM
  • Berun
    HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
    by Berun
    Hello All,
    I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
    I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
    I read the Chip on board 8 times (with power...
    04-09-2026, 06:24 AM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
