UPS output voltage
  • evilkitty
    • Nov 2017
    • 302
    UPS output voltage
    This week i had one of my UPS units (Back-UPS 650 G1) give me some trouble (it caused my system to loose power several times, either rebooted it or resulted in it being powered off; note the BIOS is configured to boot the system when power is restored)
    The battery seems fine as far as i can tell (12.5v under load), but i am only getting 90V AC when the battery is in use, 85V when there is a 75W load and the unit says the battery is good
    my other unit of the same model has similar behavior but the voltage seems to go back up after dipping down (based on visual brightness of a light bulb) then my 3ed unit of a different model looks to be holding way closer to spec voltage output
    i was thinking maybe the issue is reading AC voltage for a step based simulated sine-wave, but if i can see reduced performance in a light bulb of floor fan that is probably not the issue
    The UPS at once point turned itself off
    i can try a new battery, but is AC voltage drop expected on these units? any known common component failures that would cause this?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8756
    Maybe due to the UPS not being a true sine inverter and you not using a DMM with RMS. This will cause the AC reading to be read low.
    • evilkitty
      • Nov 2017
      • 302
      That was why i also did testing with a floor fan and a light bulb (75W incandescent) and i was able to see a visible drop in brightness and hear/feel the difference with the box fan
      note that a 75W bub should be more current than my system uses when not running prime95...
      I can't see a reason why the UPS caused my system to power cycle or why i woke up and it was powered off (like the UPS turned itself off) and i am seeing good voltage at the battery under load
      my RMS meter broke, seems like a switch/dial issue but cleaning contacts did nothing, considering a Klein's CL810 or CL490
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8756
        The CL810 is superior to the 490
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8798
          • Fixing Failed Fuhjyyus
          PCs will sometimes spike high in current when some background task runs so you can't assume idle all the time... yeah running an intricate benchmark will set it to highest utilization and your UPS needs to be able to handle it whether or not it's a "real" task...
          • evilkitty
            • Nov 2017
            • 302
            under a full synthetic load of all hardware you are gonna have a hard time getting a high wattage, everything is hyper optimized for low power draw well as far as i can go without modding the PSU to run off a battery directly
            when i say hyper optimized i mean everything (net switch, speakers, DACs, audio amp) that is near the PC (server + VM router) that runs on 5/15v is powered from the computers PSU mainly to increase the demand on the PSU to push it higher up the units efficiency curve, the only thing that is not powered by the PSU is a piece of ubiquity hardware that uses a PoE injector (24v)
            when i picked the PSU i could only find 1 better unit and i calculated the cost of running delta and if i recall it came out to needed at least 20 years of run time to break even on the price delta
            i replaced the battery and left it powered in with no load devices and it turned itself off, ugh... guess i have to open it, start pulling caps, measuring caps, and make a spreadsheet, and buy new caps
            • bauto601
              KDM 480W PSU upgrade succes! (opinions?)
              by bauto601
              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
              A "nice" YoungYear unit? - Badcaps
              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
              12-26-2023, 03:05 PM
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
            • quickname
              Cyberpower 1500AVR UPS repair
              by quickname
              I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
              I decided to verify that the batteries were...
              11-12-2023, 09:57 AM
            • Loretto
              Samsung SMPS BN44-00339A
              by Loretto
              this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
              I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
              I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
              I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
              03-29-2025, 08:30 AM
            • Loretto
              by Loretto
              03-28-2025, 10:28 AM
