Plastic body/shaft potentiometer - where to buy?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5393
    • New Zealand
    • Electronics and computer repair
    The air speed control potentiometer in my hot air station failed.
    It went open circuit on one end.
    I swapped the wires around and it works now, but backwards.
    That's fine, but I want to replace it in case it fails completely.
    They used a standard 16mm potentiometer, but the front and shaft are plastic.
    It's plastic because the control is directly connected to mains circuitry.
    (It's basically a triac lamp dimmer circuit!)
    Does anyone know where to find a replacement?
    -David VanHorn
  • harp
    • Jun 2022
    • 710
    • Planet Earth
    You can always perform a transplant operation of shaft/body on regular B500K pot... just look that dimension shape are the same.
    • mon2
      • 16560
      Which brand of air station? Contact the mfr for assistance. Many are very good on spare parts. We chose the BEST brand for this reason after meeting with them in Hong Kong at an electronic fair.
        • 31887
        i use plastic pots.
        find yourself an OMEG dealer
        https://www.rapidonline.com/omeg-eco...ontrol-65-1400
        • Agent24
          I see dead caps
          • Oct 2007
          • 5393
          • New Zealand
          I was thinking about that, but the question is, can I transplant the wiper? I wouldn't want to use the old one as it's probably worn, but if I can, that's probably a good idea.
          It's custom branded for a local electronics chain, but the OEM is ZhongDi. I guess I could ask, but I get a feeling they won't care. I couldn't find spares of the control PCBs for it either. They work, but the LCD driver perhaps seems messed up. But they work enough to know what temperature I'm at, so it's not too bad.
          Originally posted by stj
          i use plastic pots.
          I guess something like that is the fallback option, the issue with the station is the cutout for the potentiometer is not just a round hole. They have two overlapping holes kind of like a Venn diagram, and the original pot goes in the smaller one. If I tried to enlarge the small hole with a drill, it's just going to go sideways (literally and figuratively). Mounting a new potentiometer in the larger hole would make the control off-center. So I'm hoping to find something with the same bushing size.
          I guess I could file the smaller hole larger with a rat-tail file, but was hoping to avoid too much messing about.... hmm
          -David VanHorn
            • 31887
            you said the original was 16mm - so are those plastic ones.
            • harp
              • Jun 2022
              • 710
              • Planet Earth
              Not sure about plastic ones, but I think it is posible to transplant... https://m.youtube.com/watch?v=rUkrpqEmXb8 ... shaft is fixed to wiper only to ensure to not came out if pulled, otherwise, it can operate just inserting shaft into wiper. Anyway, shaft is not the same part as viper, so can be posible to change it if no other option. If you buy and replace with new, please disasemble plastic one and post photo of wiper/shaft fixture, probably only melted plastic, or metal clamp and it that case is fixable.
              • harp
                • Jun 2022
                • 710
                • Planet Earth
                Also, the wiper may not to be damaged at all (maybe need just cleaning) so in that case replacement not be needed, then it is easy fix...
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5393
                  • New Zealand
                  Yes, but the original one has a narrow bushing, M7 size. The ones you linked are M10, it would need a larger mounting hole.
                  The space behind the panel could fit a 24mm body potentiometer or even larger, but all of those have large bushings.
                  No it's definitely the track which is bad - I measure around 7 meg ohm from end-to-end, not 500K.
                  If I connect to the good end, the resistance increases normally as I turn the shaft, and right near the end I can read 500K between the track and wiper, but at the very end it goes open.
                  As I said, the potentiometer works fine when I swapped the track connection to the other end, it just works backwards.
                  But I have found what might be a suitable replacement...
                  A plastic-fronted potentiometer with switch designed for light dimmers,
                  It has an inbuilt switch, but I imagine I can just leave that disconnected.
                  https://www.aliexpress.com/item/1005005388305194.html
                  They sell them in lots of 5 for only a few dollars, so I might get some and see...
                  I haven't opened the original one yet as I didn't want my hot air station to be unusable while looking for a replacement potentiometer.
                  -David VanHorn
                  • harp
                    • Jun 2022
                    • 710
                    • Planet Earth
                    In post #8 I mean a wiper (the metal moving part crimped to shaft), so, if is not worn or damaged, it may be using that original part, only replace carbon track from new one... Be aware, if you choosing that pot with switch, you can not expect that you can do a transplantation at all if neccesary, for me, it is unclear how is mount on knob and dimension of shaft... also, you have only one side of pot...
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5393
                      • New Zealand
                      Yes but I don't know the condition of the original wiper or the design of the potentiometer internals, transplanting the parts may not be possible, I don't know. I don't want to break the original trying to find out, since it still does work (just in reverse).
                      The air control circuit only uses 2 connections, so the ones from AliExpress would work, I was thinking of replacing the whole potentiometer with one of those, as I wouldn't have to modify the front panel.
                      -David VanHorn
                        • 31887
                        if it still works in reverse then the track is cracked at the rivet.
                        strange that they chose logarithmic (B variant) over Linear,
                        unless they got them for cheap.
                        • harp
                          • Jun 2022
                          • 710
                          • Planet Earth
                          B = linear, A = logaritmic
                            • 31887
                            from an OMEG datasheet:
                            Resistance Laws (Taper):
                            Linear: A
                            Nonlinear: B - Log (Audio) or C - Antilog (Reverse Audio)
                            Other laws: Please refer to Sales office
                            PIHER / MEGGITT show the same coding
                            • harp
                              • Jun 2022
                              • 710
                              • Planet Earth
                              LOL, so yet another marking mess... "Important regional note: European potentiometers sometimes reverse these codes, with “A” meaning linear and “B” meaning logarithmic. Always verify the taper from the datasheet rather than assuming from the marking." https://pcbsync.com/potentiometer-guide/ ... to highlight in citation quote "SOMETIMES" ... in past I was confused about that, and learned in some video acronimes: A is for audio (log) and B is balanced (lin), and I think that I learn something valuable. Now I know that is bs... where is go good past time where every pot has label LIN or LOG...
                                • 31887
                                there is a 4th type, pretty rare - split-log.
                                used for the balance control in high-end audio.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5393
                                  • New Zealand
                                  Mine is linear, I tested it. The midway point measures 250K.
                                  I don't think the track is cracked at the terminal, since the resistance will go almost all the way to 500K when measured from the good end, then, when I turn the shaft right to the end, it goes open.
                                  -David VanHorn
                                  • Kemer
                                    Led status indicator light transfer plastic
                                    by Kemer
                                    Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
                                    There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
                                    The plastic piece doesn't appear to be broken.
                                    1. What are your suggestions for resolving this issue?
                                    2. Is the plastic piece made of special ma...
                                    08-19-2025, 07:02 PM
                                  • eccerr0r
                                    Heat sink plastic pins (intel specific) cracking? Just fakes?
                                    by eccerr0r
                                    I'm not sure if this is still pervasive but back in the Socket 775 and on towards a lot of the 115x series, Intel heatsink fans used those nasty to set pin-in-hole retention systems to hold the heatsink on the motherboard. Not only there's a potential to bend and crack the motherboard, I've had a few of these plastic pins blow up and the heatsink falls off. I have this one machine that constantly breaks these pins that I ended up ghettomodding it with screwlocks and a bunch of nylon washers. Not as tight as before but at least the cpu doesn't overheat anymore when the plastic pins crack!...
                                    12-31-2025, 10:07 AM
                                  • Yanleb
                                    LG 60PK550 Logic Control Board EBR63450301
                                    by Yanleb
                                    Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                    C57: 3.30V
                                    C61:...
                                    07-20-2023, 12:38 AM
                                  • waigy
                                    Variable resistor potentiometer has different reading when mounted on the board
                                    by waigy
                                    In my fusion FE-402 car amplifier the gain pot is an RK097G.
                                    I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
                                    The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
                                    I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
                                    I then took the pot out the board and it now measured 22k.
                                    I tried putting it back in the board and it goes back to 10k.
                                    Is this normal and if so what pot should I order?
                                    On this...
                                    11-12-2024, 04:44 AM
                                  • jkruns
                                    Macbooks Black plastic insulator material - how to replace?
                                    by jkruns
                                    On recent Macbooks there's an increasing amount of black plastic insulating material, covering sensitive components. Starting with the A3113 (M3 Air) the entire logic board is covered with a single sheet of this stuff. I've never managed to remove these covers without deforming or damaging them, let alone keep the edges sticky enough to adhere a second time.
                                    Question to the seasoned pro's here: after you repair a logic board, do you replace this plastic film, stick on the remnants of the original one or leave it bare?
                                    Can you buy this material so you can make your own? Kinda...
                                    03-10-2026, 01:38 AM
