Breadboard resistance
  • Billathome65
    • Apr 2026
    • 18
    • Growing Veg, walking the dogs and messing with sparky things Amplifiers etc.
    Hi I'm currently trying to repair a Kenwood KA-76 Amp I stupodly damaged and need to check a risser board to see If there is a problem with that.
    This is a schematic of the board showing 50V but also 20V
    If I put it into a breadboard to test what rate resistors would I need to use 10KOhm?
    Cheers Bill
  • Billathome65
    • Apr 2026
    • 18
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8824
      • Fixing Failed Fuhjyyus
      Not clear what you're trying to accomplish here... normally I don't use a breadboard and just test while the device is installed, or is it because it's in an inaccessible location?
      • Billathome65
        • Apr 2026
        • 18
        No i'm trying to track down a short that only shows when the board is soldered onto the main PCB trying to work out if its an issue on the main board that shows up once connection is made to the riser or if its the riser itself that has the problem. The riser is a pain to solder in and out again so want to try to check it off the board as if thats possible?
        2 resistors burnt out on the rise on the 50V trace.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8824
          usually resistors go open when they fry so it should be fairly quick to just see if any semiconductors shorted...running these custom boards out of the original device is quite a challenge...
          • Billathome65
            • Apr 2026
            • 18
            Cheers eccerr0r
            • Billathome65
              • Apr 2026
              • 18
              Cheers. I tracked down the short to one of the transistors.
              The strange thing is it was reading fine in circuit but I noticed that when measured in the TC1 tester it read as a diode? However the other transistors read as transistors, so this was strange.
              As it measured fine I reinserted and when I checked resistance it was showing a short between legs but not off board?
              I ensured there was no solder bridge then replaced with another and the short disapeared.
              Not had chance to reinstall the board yet due to a couple of fractured ribs but I hope when its reinstaled on the main board there is no constant bright light on the dim bulb tester.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8824
                I suspect bipolar junction transistors can short out one of the two junctions and have the other one still work like a diode, so it's possible universal testers may identify it as a diode.
                Still suspicious, usually these tiny to92 transistors even when shorted won't cause power fuses to burn...thing would have to pass quite a bit of current to do so and they weren't designed to do so...
                • cind12
                  GTX 1080 TI Gigabyte Aorus low resistance on vmem
                  by cind12
                  Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                  Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                  The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                  Resistance on 12V 4K ohms (Power present when on)
                  Resistance on 12V PEX 4K ohms...
                  12-08-2023, 09:09 AM
                • CharlesBHaskins
                  RTX 2060 Laptop VRAM Rail Resistance
                  by CharlesBHaskins
                  I'm checking the VRAM power rail on an RTX 2060 laptop GPU and I'm not sure whether the resistance I'm measuring is within the normal range.
                  Has anyone measured the VRAM rail resistance on a similar board? What values did you get, and how can you tell if there's a short?
                  Thank you so much!
                  06-18-2026, 01:11 AM
                • Nagy Daniel
                  Lowest possible resistance on laptop motherboard rail - Guide Table request
                  by Nagy Daniel
                  Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                  I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                  I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                  So, I generated a table with AI so I can...
                  03-04-2025, 08:24 AM
                • mmx01
                  Palit GTX 980TI working via a riser but not in x16 slot
                  by mmx01
                  Interesting case, I have a gtx 980ti which suffered typical drmos failure. I replaced it together with 12V PEX switching transistors, all blown fuses etc. No shorts on vcore, vmem, pex or any other rails.
                  Yet the card does not give any sign of life when plugged into pcie x16 slot unless I plug it in via a mining riser?! I was troubleshooting it using riser as it is easier to measure etc. It worked so I assembled the card put in the computer and no post. When I move it to the riser it works again.
                  Checked all voltages on PCIE finger 12V, 3V3 while...
                  10-29-2022, 05:43 AM
                • mcraze123
                  ASUS GeForce RTX 4060 Dual OC - Water Damage / 1.8Ω Short on 12V Rail / Blown Trace & High-Side FET Repair (Log)
                  by mcraze123
                  Sharing a component-level repair log on an ASUS GeForce RTX 4060 Dual OC that came across the bench with liquid damage and a hard power fault. Initial Assessment & Cold Rail Measurements
                  • Symptom: Card caused the ATX host bench power supply to trip over-current protection (OCP) immediately upon power-up.
                  • Visual Inspection: Evidence of localized water ingress and corrosion around the main input stage and power delivery circuitry, with a physically blown PCB trace near the 12V input filter section.
                  • Cold Resistance Sweep:
                    • Main 12V PCIe power rail measured 1.8 Ω to ground—indicating a
                  10-30-2026, 01:43 PM
