Comparable to NTH040N06NC?
  • samtron786
    • Aug 2016
    • 178
    • germany
    Hello everyone, I'm looking for this MOSFET or a comparable one, NTH040N06NC.
    Thank you very much.
  • lotas
    • Jan 2016
    • 5359
    • Russia
    You can see a photo of this mosfet, otherwise even Google doesn’t know this mosfet number.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8688
      Try Google nth040n06c and get it from LCSC.
      • lotas
        • Jan 2016
        • 5359
        • Russia
        There is a datasheet for the NTH040N06C, I saw it, but I can’t find the NTH040N06NC specifically; apparently the author made a typo.
        • samtron786
          • Aug 2016
          • 178
          • germany
          You're welcome.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8688
            So it is ending with a C. Thought so. Try sourcing it from LCSC or TME.
            • samtron786
              • Aug 2016
              • 178
              • germany
              Hello, what can I do now?
              Is there another MOSFET available, or does it have to be the same one?
              • samtron786
                • Aug 2016
                • 178
                • germany
                Could you please provide a link?
                • lotas
                  • Jan 2016
                  • 5359
                  • Russia
                  https://www.ebay.com/itm/196647555423
                  https://www.lcsc.com/product-detail/C7427706.html
                  https://www.aliexpress.com/i/3256806675439084.html
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
                  • Nooy
                    VGA MOSfet permanently shorted and loss of MOSfet pad
                    by Nooy
                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                    02-14-2024, 02:26 AM
                  • potrebitell
                    Lenovo L340 Gaming – input MOSFET overheating / unstable power path
                    by potrebitell
                    Laptop was liquid damaged and cleaned. I removed one shorted capacitor found via injection.
                    Issue now:
                    • DC jack provides ~20V
                    • First input MOSFET drain has 20V, but source drops to ~0V unless lightly pressing the MOSFET area.
                      When lightly pressing the input MOSFETs, the laptop starts drawing current and CPU/GPU VRM “squeals”.
                    • With slight touch/pressure the laptop actually powers on, starts drawing current, but rapidly begins to overheat heavily the first input MOSFET. As soon as I remove my finger, it immediately shuts off again (it cannot stay on because the MOSFET
                    05-20-2026, 09:43 AM
                  • Tomylee
                    HP 15-fc0007ca Charger Cycling On/Off with Hot MOSFET – Need Component Info
                    by Tomylee
                    I have an HP 15-fc0007ca that works normally, but when I plug in the charger while the laptop is powered on, the charging cycles on and off repeatedly—it starts charging, stops, then starts again.
                    Using a thermal camera, I identified a MOSFET that is overheating, along with a small 2R2 resistor next to it that gets even hotter than the MOSFET.
                    I also hear a “zpzpzpzp” type noise, but the noise is not coming from the same area as the hot MOSFET. I will include a photo with the exact spot where the noise is coming from highlighted.
                    11-26-2025, 12:24 PM
                  • redbaron1007
                    Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                    by redbaron1007
                    I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                    Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                    09-09-2025, 11:10 AM
