Need for testing short something draw 5,10 or 15 amp
  • macattack600
    • Aug 2011
    • 97
    I need a idea for something that will draw at least 5 10 or 15 amps that will be powered by a ATX power supply's 12v rail.
    I had a led strip but its not long enough. Something around the house if anyone has any ideas.
    People keep telling me this does'nt work but I'm using it to find a short to ground on a motherboard
    I attach the 12v rail to the opposite 2nd mosfet of the one of the 2 that takes 18v turns into 12v to tell the board ok to start. Have a ground wire on ground of board to the positive end of led strip wire ,-from the ground of the led strip- to the ground on the PSU, power PSU with tweezer.
    ----The board first got hot but the led strip I have is too damaged for me to further test I felt the GPU only warm up on 1 board. I want need to feel the heat from the board in the area of the short.
    Re: Need for testing short something draw 5,10 or 15 amp
    "I need a idea for something that will draw at least 5 10 or 15 amps that will be powered by a ATX power supply's 12v rail." Are you saying you want the load that will draw 5A, 10A, 15A from 12V power supply?
    The load or what ever you connect to the power supply output will dictate how much current it will want to draw from the power supply.
    http://www.edn.com/design/test-and-m...acer-technique
    http://www.edn.com/design/pc-board/4...gineering-PCBs
    http://www.edn.com/design/pc-board/4...uses-low-power
    What are you working on? Pictures, make and model.
    • macattack600
      • Aug 2011
      • 97
      That info is good but it does'nt help
        I thought you wan to be able to locate shorts circuit. So what is the 5A, 10A, 15A question is about? Info and pictures on what you are working on will us helping you.
        • macattack600
          • Aug 2011
          • 97
          I am wanting to put a demanding load on the output of the ground on motherboard, using the 12v PSU rail connected to a mosfet
          but the led strip I have isn't enough . So in this order, PSU-motherboard-led strip or equivalant, -back to PSU in that order. The board is the middle man to maybe a light source that is drawing the amps but I don't know what I could use maybe lamp type LED light bulb?
          Since there is a short to ground on the mobo I should be able to feel it get hot is the end result i'm looking for.
            OK if that you want to do using 12V power supply for locating shorts then to draw 5A from 12V, the resistance that the power supply has to see will be 2.4 Ohms, so if the shorts circuit circuit resistance or what ever the resistance on the board is, which you need to find out then the added load connected between the mother ground and the negative terminal of the 12V so the total resistance cannot be higher than 2.4 Ohms to allow 5A to be drawn from the power supply, Ohms law.
            BTW 12V @5A is 60 Watts of power!
            • macattack600
              • Aug 2011
              • 97
              I don't think i'm getting this across right but thank for the information.
              I've seen this done before where the board was the middle man and the output was a whole bunch of led lights putting demanding load on the in between motherboard and the gpu was the one getting hot I just don't have while bunch of led rope. Trying to find something equivalent
                Using LED, RESISTORS or what ever, the power supply has to see 2.4 Ohms to get 5A draw. Yes the board is the middle man and it is connected in series with the LED/RESISTOR or what ever. The current draw from power supply is dictated by the total load resistance.
                • macattack600
                  • Aug 2011
                  • 97
                  so actually I would want to put like a halogen bulb before the motherboard back to the psu
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4940
                    • New Zealand
                    If the motherboard is shorted the bad part will heat up when you apply power. The trick is having enough juice from your power supply, and not have it shut down when the PSU sees the short.
                    It sounds to me like the LED strip is simply for current limiting so the PSU doesn't shut down when you are testing. The LED strip is not for "pulling more current through the short" - A short circuit by definition will try to pull as much current as is being supplied!
                    -David VanHorn
                      Check the resistance of the bulb, the cold resistance will be 10 times lower than hot resistance, the lamp has positive resistance, as it heats up the resistance goes up, so as you start drawing current, the resistance will go up so the current draw will go down.
                      Agent; I hope you can explain it better than I can about the current draw, I think he needs to understand the relationship between Voltage, resistance, and current. Seeing how it is done and understand why it is done that way, and what the expected result is will be a big help for him to understand.
                      • macattack600
                        • Aug 2011
                        • 97
                        So it would be enough for a lamp like led light bulb before or after the motherboard for current limiting? What size should I use.
                          Agent: please do the explanation, I cannot do any more.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4940
                            • New Zealand
                            OK, I'll give it a go.
                            macattack600: You need to understand Ohm's law for this to make sense. The basic idea is that Volts (V) = Current (I in Amps) x Resistance (R in Ohms). Very basic maths here.
                            What we have is the equation V = I x R.
                            This can be rearranged to find current or resistance also.
                            To find current it's I = V divided by R (or I = V/R) and to find resistance it's R = V/I.
                            So for example: If you connect the shorted motherboard to the 12v rail as is, and want to find out how much current it will draw.
                            The shorted motherboard will have a very low resistance. Let's say it's 0.1 Ohms.
                            You can even measure this resistance from the 12v rail input to ground with your DMM, but 0.1 is a good start, it will be something close.
                            So, we would say I = 12v / 0.1 Ohms, which gives us 120 Amps! Yes, the shorted motherboard wants to draw 120A from your 12v rail. This is a crazy amount of power and the PSU can't even supply it, so it shuts down to prevent itself from being damaged from this overload. This means that we can't do any testing. It also means that if we gave the shorted motherboard all 120A that it wanted, it would go up in flames. That doesn't help either.
                            We need a way to limit the current flowing through the board, so that 1) Board doesn't catch fire and 2) PSU doesn't shut down.
                            This is where the LED string etc in series with the motherboard comes in.
                            -David VanHorn
                            • macattack600
                              • Aug 2011
                              • 97
                              Got it very good detailed answer. I will overnight the led rope. Thank you for such a detailed answer you've both been great help.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4940
                                • New Zealand
                                There are some more things to know here. 1) The LED string has its own resistance, 2) When resistances are in series, they add up. and 3) The current through series-connected resistances is the same.
                                Let us say for example that we have an LED string that is 2.4 Ohms (note I am oversimplifying it, but the point is valid)
                                Again, if we check Ohm's law we get I = 12v/2.4 Ohms which equals 5 Amps.
                                If we connect the LED string to the PSU, it will draw 5 Amps. The PSU will not shut down because 5 Amps is a pretty small load for a PC power supply.
                                Now think about the LED string and shorted motherboard in series, eg:
                                PSU 12v ------>[Shorted Motherboard]------>[LED String]-----|
                                PSU GND <---------------------------------------------------|
                                Power will go through the motherboard AND LED string, and return.
                                Remember the motherboard is 0.1 Ohms, the LED string is 2.4 Ohms. We add them and the total is 2.5 Ohms. This works out at 12v, for a current of 4.8 Amps.
                                This means 4.8 Amps will be drawn through BOTH the LED string and motherboard. This also means the PSU won't shut down, and the motherboard (will hopefully) not catch on fire.
                                -David VanHorn
                                • macattack600
                                  • Aug 2011
                                  • 97
                                  How much rope light do you think I need 12ft 24ft ? The more the better
                                    • 30965
                                    halogen lamps make a good resistive load.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4940
                                      • New Zealand
                                      I don't know. It all depends on what its specifications are. Do you have a link to some more information about these lights?
                                      The easy way would be to find an LED string that works on 12v and draws whatever current you wish to test the motherboard with.
                                      But as budm pointed out, 5A @ 12v is pretty high for short testing, you may still roast the shorted part (and this can result in damage to the PCB which is beyond repair)
                                      With equation Watts (P) = V x I, your 12v x 5A is 60 watts!
                                      You may wish to start with something small like 500mA, and increase from there if nothing gets noticeably hot or starts smoking.
                                      You could get by with a simple 10-watt, 24 ohms resistor for 500mA (which would be dissipating 6 watts)
                                      -David VanHorn
                                      • macattack600
                                        • Aug 2011
                                        • 97
                                        What size type you recommend.
                                        • playit
                                          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                          by playit
                                          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                          09-02-2023, 02:43 AM
                                        • MisterAIL
                                          820-00840 / No boot / PP3V3_G3H Short to ground
                                          by MisterAIL
                                          Firstly sorry for my english, french guy inside.
                                          I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
                                          History is a day, nothing happened when opening the laptop.
                                          Nothing special inside, no corrosion, no liquid damage, never opened.
                                          First, with the logicboard alone on the desk, mesures are :
                                          5v017 and 0.000 amp. nothing else.
                                          Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
                                          10-13-2021, 11:42 AM
                                        • triplefour
                                          Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                                          by triplefour
                                          Samsung UN55ES7003
                                          made house call.
                                          red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                                          psu has self test feature.
                                          disconnected from mainboard.
                                          determined PSU ok BL ok.
                                          suspect mainboard.
                                          disconnecting tcon has no change on operation.
                                          markings on mainboard:
                                          BN97-06531P 0151
                                          BN94-06123R
                                          found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                                          for 54$
                                          second house call:
                                          with replacement mainboard, tv turns on, has sound,...
                                          07-13-2022, 03:53 PM
                                        • Prott
                                          PS5 - long screw damage, via to ground layer short?
                                          by Prott
                                          Hello dear Badcappers,
                                          I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
                                          Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
                                          07-27-2024, 08:54 AM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
