Help needed - Instrument cluster repair - Ford
  • Petar92
    • 14
    • Austria Wien
    Hello guys! I know this might not be the stuff you see every day, but I know this is the place with ppl who know this stuff.
    I have trouble diagnosing the fault on this instrument cluster. When +12v is applied to pins of the white connector, this IC (marked red ) gets hot within seconds. I have already tried to replace it with another one, same deal. The IC is Infineon TLE 62366
    As I dont have much experience, but know some basic stuff, soldering etc. I would appreciate any pointers to what to seach, what and how to check.
    Thanks in advance!
  • pdblues2231
    • Jun 2022
    • 60
    Diagnosing those boards is a pain in the neck..however, you can check the basics. have you checked those capacitors for any shorts and also check the input to the cluster make sure the voltages are correct. BTW what is the problem with the board and are those burn marks by connectors?
    • Petar92
      • 14
      • Austria Wien
      Thanks for answering pdblues2231 !
      The pointers wont move, there is no backlight... I have tested most if not all capacitors for continuity, no shorts there.
      Those are pen marks, as I was marking the pins. Then I applied freeze spray to see where the short is, thats how I saw the ic getting hot instantly, and got my pen marks all messed up
      • pdblues2231
        • Jun 2022
        • 60
        hummm
        when you say that you tested caps for Continuity what exactly do you mean.. caps should not have continuity across their terminals like a wire does. I don't believe the ic is the problem as you already changed it and yield same results. That IC is some kind of smart switch. Check voltages coming into board.
          • 31612
          you need a datasheet for the chip,
          what happened to the connector, why does it look like soot in that area?
          • truclacicr
            • Apr 2019
            • 379
            • australia
            https://www.badcaps.net/download/?id=e00b551d
            Pin 24 is the output of an internal 5V regulator. I would check for a short to ground at this pin.
            • Petar92
              • 14
              • Austria Wien
              Originally posted by pdblues2231
              hummm
              Yup, I used continuity mode on my multimeter as I dont have one with capacitance, and check if there are caps which are shorted through. none were. I will, thanks for help!!
              • Petar92
                • 14
                • Austria Wien
                i think this is wrong datasheet, tle 62366 is my IC.
                • Petar92
                  • 14
                  • Austria Wien
                  just explained a bit up the thread. just pen markings i did to label the pins. I have a datasheet, but unsure what should be the next step.
                  • truclacicr
                    • Apr 2019
                    • 379
                    • australia
                    Sorry.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8495
                      That big cap you took out, where the marking D70 is, one leg looks like you made a solder bridge. Second pic, top, next to the AX120xxxxxx chip.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5309
                        • New Zealand
                        • Electronics and computer repair
                        Isn't that just the tear-drop style pad they've used?
                        -David VanHorn
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8495
                          To me it looks like the trace is shorted to the GND and way too much solder there.
                          • Petar92
                            • 14
                            • Austria Wien
                            That is oem solder spot, didnt touch that. Those are pins from capacitor on the other side.
                            • pdblues2231
                              • Jun 2022
                              • 60
                              How far have you gotten with this?? Any progress??
                              • Petar92
                                • 14
                                • Austria Wien
                                Hello!
                                got a replacement unit to eliminate issues with car. replacement works fine.
                                swapped main cpu of original unit to replacement to get correct odometer on replacement unit.
                                I could now play with original unit that is faulty, but no ideas what to try next.
                                Best regards
                                • Petar92
                                  • 14
                                  • Austria Wien
                                  UPDATE !
                                  New cluster with old cpu that I swapped now wont work.. So I guess we found the main source of fault. I am now going to swap back new cpu to new cluster, to see if it works like it did last week when I tested positive..
                                  • pdblues2231
                                    • Jun 2022
                                    • 60
                                    Ahh, I guess process of elimination also works. Just be careful the old cluster may damage the new cpu. and sometimes these cluster will marry certain components..
                                    • Petar92
                                      • 14
                                      • Austria Wien
                                      yup, thats just what happened....
                                      after i installed new cluster with original mcu swapped, the cluster didnt work, and after 10-15 seconds the backlight and lcd died....
                                      so i guess i burned replacement cluster by soldering old mcu onto it.
                                      I just resoldered the mcu the replacement came with back, and got same results on the bench. on initial powerup, turns on shortly, then lcd looses info, then backlight slowly dies, all within 10-15 seconds.
                                      Switch off then on causes backlight to come on dim for a second then dies.. it lasts shroter every time I cycle the power.
                                      now im ready to go straight to ford and order new cluster no matter the cost... unless anyone have any suggestions what could be fried..
                                      • pdblues2231
                                        • Jun 2022
                                        • 60
                                        Unfortunately that's how all modern electronics are. The BCM controls all of this so without the proper software and programming tools it simply can't be done. these are smart chips and switches and they will not work without programming. All required data such as odometer, theft deterrent and lighting must be programmed. The cluster may still be good just needs to be reprogrammed for your vehicle.. good luck
                                        • Kuhanzzi
                                          Component identification help needed - Ford seat heater
                                          by Kuhanzzi
                                          I need some help with identifying this component on a Ford Mondeo seat heater control unit PCB
                                          Markings B1s on the top.
                                          Size approx 1.6 x 3.0mm
                                          Pin sizes approx 0.3mm, 0.6mm and 1.2mm
                                          03-17-2026, 07:23 AM
                                        • JayPoorJay
                                          Glueing Two Sided Flex Ribbon,Jaguar XJS Instrument cluster.
                                          by JayPoorJay
                                          Hello All.
                                          I'm working on the printed flex circuit board (flexible type) of a 1990 Jaguar XJS Instrument cluster. If you Google that you'll be able to get a general idea.
                                          In areas, the plastic has come apart allowing the copper strip to kinda flop around and be exposed to the elements.
                                          What can I use to glue the 2 faces of the plastic material together trapping the copper ribbon inside...
                                          Again - thank you all for you help. This will be the 4th or 5th time now that I have come here to receive AMAZING advise and directions. Thanks so...
                                          05-03-2022, 09:56 AM
                                        • dbuergi
                                          Minisforum G7 PT7945 Bios needed
                                          by dbuergi
                                          when i start this machine i get LEDs and all voltages but only one fan spinning at full speed and no picture or any booting.
                                          Bios reset didn't help.
                                          If needed board number should be DRBAA V1.0
                                          HD506VG7PTEDMPE00125...
                                          04-03-2026, 03:56 AM
                                        • Swatou
                                          Dell OptiPlex 3090 Micro – Clean SPI BIOS dump needed (password locked)
                                          by Swatou
                                          I bought a used Dell OptiPlex 3090 Micro with a BIOS administrator password that I cannot remove. Dell support refuses to help without the original proof of purchase, and the seller is unreachable.
                                          I would like to try flashing the BIOS chip with a CH341A programmer, but I need a clean SPI BIOS dump for this exact model.
                                          Here are my machine details:
                                          Service Tag: 50P1BB3
                                          Express Service Code: 10925963391
                                          Form factor: Micro
                                          I can share my current BIOS dump (read with CH341A) for comparison if needed....
                                          03-24-2026, 11:25 AM
                                        • sterncan
                                          Samsung Odyssey G9 BN94-17725A SPI flash dump needed (T9549 / NT68500)
                                          by sterncan
                                          I am repairing a Samsung Odyssey G9 monitor.
                                          Model: LC49G94TSSRXZG
                                          Mainboard: BN94-17725A
                                          PCB: BN41-02843B
                                          Scaler: Novatek NT68500 (T9549 platform)
                                          Flash: Winbond W25Q128JVSQ (16MB)
                                          Problem:
                                          Monitor only shows standby LED.
                                          No backlight, no OSD.
                                          SPI flash verify is OK.
                                          Original dump seems corrupted or boot structure damaged.
                                          I am looking for a full 16MB SPI flash dump
                                          from a working BN94-17725A board.
                                          I can share my original dump if needed.
                                          Thank you very m...
                                          02-26-2026, 05:32 AM
