Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Great video on WHY cheap lithium cells are dangerous
    No photos found.
  • Boardview and Schematic Bot
    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
    by Boardview and Schematic Bot
    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
    09-12-2024, 02:00 PM
  • Gjackson
    Bad Video on a cheap MASTER LCD TV,Motherboard model: tp.s506.pb801
    by Gjackson
    Hi all, I have a cheap LCD with a cheapo brand name "MASTER", it's one of those sets with a single PCB (Motherboard model: tp.s506.pb801) that handles everything. It powers up fine but shows signs that usually indicate a TCON problem (see images) however there is no TCON to troubleshoot, where should I start troubleshooting, on the mainboard? or the LCD's PCB? I tried tapping the thin LCD PCB while it was running and only got a change in video when I tapped a certain IC on the board (see picture below, IC circled in red) and the screen went dark and came back but now it was white instead...
    06-09-2022, 11:12 AM
  • japlytic
    Gigabyte Z690 UD AX DDR4 distingusihing failures+default video
    by japlytic
    On this motherboard with a CPU (requiring discrete graphics) supported by the BIOS (version F3) and a new video card, it has a beep code indicating a CPU failure while the onboard diagnostic LEDs indicate a video system failure and using a different motherboard of the same model had the same result despite confiriming that the new video card along with the power supply as well as the connected display/cable was operational in another system.
    So therefore, I've found that the Video diagnostic LED illuminated before CPU diagnostics were performed and since the CPU has failed, video diagnostics...
    12-30-2022, 11:12 PM
  • larSS
    MSI MS-16JF no video memory power supply
    by larSS
    Hello! Has an msi ms-16JF motherboard with a diagnosis "doesn't work". There were a short-circuit on video memory lane. Removed GPU and video memory, changed TPS51916 and transistor on it's lane. Motherboard works OK, has the initialization and video card voltage. But has no video memory voltage. Should there be a video memory voltage without video chip or no? Has the S5 signal 3.3V on TPS51916
    10-28-2023, 09:24 AM
  • yayayee
    ASUS GU502GV not powering on - 1285A hot
    by yayayee
    I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
    So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
    I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
    01-08-2024, 11:04 PM
