What are the pro's and cons of replacing a 1/4 with a 1/2 resistor same ohms?
  • Baste
    • May 2025
    • 19
    • Philippines
    As the title says. I bought a cheap Asus ROG Strix 750-watt PSU, which was posted as defective. Cables are complete, and the entire PSU is in good condition, of course, aside from being faulty. Long story short, upon checking, there is no +5VSB. Looking at the components, I found a blown resistor. I swear, looking at the bands, the color is pink, pink, gold, gold. I dunno if I'm color blind or this is the way resistors are coded.
    Please help, did I decode it correctly at 2.2 ohms (red, red, gold, gold), or what could a pink, pink, gold gold value be? I bought a 2.2ohms, but it was a 1/2 watts can I use this 1/2 W replacement over a 1/4. The resistor is located in the PCB R105.
  • pdblues2231
    • Jun 2022
    • 53
    hi ,there
    it does look pick on pic but am sure its red.. you can use the 1/2 watt over the 1/4 just as long as the resistance is the same. the 1/2 watt would be more durable.
      • 31304
      resistor colours dont include pink.
      and resistors dont burn for no reason - you have a bigger issue to find.
      • lotas
        • Jan 2016
        • 4919
        • Russia
        Most likely, it is the current resistor R501 that is located in the U501 PWM standby mode harness.
        • harp
          • Jun 2022
          • 648
          • Planet Earth
          "there is no +5VSB".......... is it shorted to ground? Diode usualy die.
          • lotas
            • Jan 2016
            • 4919
            • Russia
            It's unlikely that the problem is in the diodes, but rather in the PWM.
            • Baste
              • May 2025
              • 19
              • Philippines
              Quick update:
              Been away for a while, my son got hospitalised, but we are home now. To answer the questions, I changed the 1/4 watts to 1/2, which fits snuggly (Red, red, gold, gold ), and the thing fired up.
              I agree with you, I forgot to mention in the post that I found some kind of bug or small insects inside when I first opened the PSU that might have contributed to the resistor short.
              I'm no expert, I think you're right that the resistor goes to the relay, which is part of the PWM.
              Code:
              No, it's not shorted to ground, no diode is busted.
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
                Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                09-07-2024, 03:10 AM
                Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                This specification for the Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold Acer 14'' boardview and SF114-34-P25P + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                Acer Swift SF114-34-P2H0 + Pack Gold Notebook 1 Specification for Upgrade or Repair
                This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold boardview and SF114-34-P2H0 + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                09-07-2024, 02:20 AM
