Repairing a ENERTRES Biomass BI-650 heater
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi all!
    A friend asked me to repair his biomass (pellet) heater. This heater has a pellet feeder powered by a relay that's not switching anymore
    I measured the voltage at the relay coil socket while entering the individual tests procedures and it has 6-7v while the relay is NOT on the socket, and drops to 0v when the relay is plugged in the socket, like the source is providing nearly 0 mA. I measured the relay coil and it is correct and not shorted so the issue is in the board, fed no amps to this output
    I checked the board at home and this output is driven by an dual OpAmp LM358 (see pictures). This IC uses pin 1 to output to the relay socket and pins 2&3 for inputs. I checked voltage supply to this IC and Pin 4 (V-) has -12.6v and Pin 8 (V+) has +14.8V. Not balanced but I guess this is normal (?).
    As the owner has only partial interest in the board to be repaired (pellets price has gone x3 in the last years in Spain) I don't think a quick repair can be done here.
    • Option 1: Replace IC LM358, a little out of my scope as I don't have much practice with SMD IC's and my poor sight won't help...
    • Option 2: Weird solution, as this output still has some "power", providing 6-7v while no load, would you apply something here (maybe a darlington Q) to increase the power to feed the relay and have a "patch solution" for a while?
    Or can you suggest another way to solve it with my limited skills?
    Thanks in advance!
  • truclacicr
    • Apr 2019
    • 316
    • australia
    Measure the voltage on each side of the 470 ohm resistor.
    • lotas
      • Jan 2016
      • 4602
      • Russia
      Something strange connection, for the operational amplifier LM358 to directly control the relay coil, there must be at least a "key" transistor or something like ULN2003 (DARLINGTON ARRAYS)
      • edugimeno
        • May 2017
        • 581
        • Spain
        Thanks, the fact is that when I got there, there had been another guy, an electrical guy, who left some relays around there, of varied voltages like 6V and 9V, and left the place saying the issue must be at the board as none of the relays work... This makes me think, maybe he modified something in the circuit and what was in the relay socket was not a normal mechanical relay?
        What could it be? An electronic relay? There was a rail mounted relay socket, that's all I found there
        • edugimeno
          • May 2017
          • 581
          • Spain
          You mean the resistor between the OpAmp output and the header right? I can't get a valid measurement now as I got this board at my house (15 km from the original machine) and I can't force the output to HI, but if we find out the relay should not be a normal mechanical relay, I will be back there soon
          • edugimeno
            • May 2017
            • 581
            • Spain
            I talked to the owner, he said the electrician left saying the relay wasn't working and he was going to find another relay, he took the original. Then he came back with a bunch of other relays and none worked. I bet there was a solid state relay and he tried to replace it with a mechanical relay? Does it make sense? Do you thing there are SS relays that match pinouts with classic mechanical relays to use their sme socket? Maybe he swapped the socket too. He's calling this electrician to ask for a photo of what he took
            • lotas
              • Jan 2016
              • 4602
              • Russia
              So how am I supposed to know what's there and how it's connected? The board is in front of you...
              How can you trust a simple electrician with complex equipment?
              • edugimeno
                • May 2017
                • 581
                • Spain
                No, I have the board, but the board is part of a large machine installed at the basement of this building. I only took the board. The relay socket (din rail mounted) along with other boards and modules were left in the machine, from which I took no photos... The owner is asking the electrician for the original relay PN or a photo
                • lotas
                  • Jan 2016
                  • 4602
                  • Russia
                  Yes, without a photo, and even with a photo, it is difficult to imagine how everything is connected and how everything is interconnected. Maybe where the relays are located, there are additional components that control the relay itself...
                  • edugimeno
                    • May 2017
                    • 581
                    • Spain
                    No worries, maybe you misunderstood me. I was just asking what would be the "usual" device to have out of the board to be controlled directly by the output of an OpAmp in order to drive a 220v AC motor. Assuming the electrician didn't change the socket, I guess there would be a SS relay, but anyway my friend is going to find out soon when the technician sends a picture of the "relay" he took., I am 100% positive the board itself has not been altered my any means, but any component out of the board might...
                    Thanks!
                    • lotas
                      • Jan 2016
                      • 4602
                      • Russia
                      Here, maybe, on these contacts, as you say, not only the output through the resistor lm358 is suitable. What is the marking of this chip?
                      • edugimeno
                        • May 2017
                        • 581
                        • Spain
                        That IC is an LF444 (Quad OpAmp), I already checked it before, it has some inputs connected to some other headers (I guess sensors) at the board, it seems like one track is connected to the same header (see scratched varnish) but I removed the header and this track goes across to another header on top if it. I checked and there's no electrical connection at all between this LF444 and the pellet feeder output header
                        • lotas
                          • Jan 2016
                          • 4602
                          • Russia
                          It is clear from it that it has already been soldered or replaced (not factory soldered).
                          Maybe there is some kind of opto relay there (a 470 Ohm resistor limits the LED current), and not a regular one with a coil.
                          • edugimeno
                            • May 2017
                            • 581
                            • Spain
                            I think what you are seeing is the remain of flux from when I desoldered the header that drives the relay for the pellet feeder, right on top of the LF444, but I didn't touch that IC at all, and I am the only one who has touched this board. No, I don't think this IC has anything to do with this function, which seems to solely relay on the LM358, the LF444 is used for INPUTS, as it is wired to other headers for detectors.
                            Im still awaiting for the owner to get a picture of the original relay that the electricina removed
                            • edugimeno
                              • May 2017
                              • 581
                              • Spain
                              Ok, we got a reply from the electrician, this is the relay he removed, it looks like he swapped the socket as well...
                              Eltako ER12-001-UC
                              So GPT states that this is NOT a SOlid State relay but it is electronically triggered (darlington inside?) so it takes really low power and also it says it works by pulses (toggle??) so it won't take current while ON...does it make sense?
                              • truclacicr
                                • Apr 2019
                                • 316
                                • australia
                                https://www.eltako.com/fileadmin/dow...nternet_gb.pdf
                                State-of-the-art hybrid technology combines advantages of nonwearing electronic control with high capacity of special relays.
                                Universal control voltage 12 to 230 V UC.
                                Low switching noise. Contact position indicator with LED.
                                Integrated free-wheeling anti-surge diode (A1 = +, A2 = -).
                                By using a bistable relay coil power loss and heating is avoided even in the on mode.
                                • edugimeno
                                  • May 2017
                                  • 581
                                  • Spain
                                  Thanks. The owner is going to find another relay, same part number this time, and see what happens
                                  Will keep you all posted. Thanks
                                  • edugimeno
                                    Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                    by edugimeno
                                    Hi everyone!
                                    I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                    I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                    This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                    To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                    I respected the polarity, positive to cathode of protecting diode
                                    So provided all...
                                    04-18-2024, 01:15 PM
                                  • edugimeno
                                    Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                    by edugimeno
                                    Hi!!
                                    Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                    I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                    At a certain point, moving stuff around, I put all wires back in place and...
                                    03-24-2024, 02:31 PM
                                  • jm1234
                                    9V relay temperature 40C
                                    by jm1234
                                    Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                    I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                    05-09-2024, 03:03 AM
                                    Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                    by sam_sam_sam
                                    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                    12-16-2023, 08:39 PM
                                    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                    by sam_sam_sam
                                    I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                    Found shorted diodes on main controller relays there are 3 of them that...
                                    01-07-2023, 05:43 PM
